Old 03-28-2013, 06:12 PM   #1
theodore
theodore's Avatar
Default torque tube hook up
I am getting ready to hook up the torque tube on my 34 roadster. I have a new driveshaft roller bearing and the speedometer drive gear snap ring that secures it. Should I install the bearing before or after the driveshaft is attached to the differential? Thanks for you help.
theodore is offline   Reply With Quote
Old 03-28-2013, 07:15 PM   #2
Tim Brown
Tim Brown's Avatar
Default Re: torque tube hook up
I usually install those parts after.
Tim Brown is offline   Reply With Quote
Old 03-28-2013, 07:22 PM   #3
hotcoupe
hotcoupe's Avatar
i would attach the driveshaft to the differential,bolt the torque tube to the banjo housing and then install the roller bearing, part #7290 thrust washer and then speedo gear and finally snap ring. you didn`t mention the front seal, now would be a good time to change it. of course you have to take the race out to get to the seal. your call.
hotcoupe is offline   Reply With Quote
Old 03-28-2013, 07:30 PM   #4
Bassman/NZ
Bassman/NZ's Avatar
I did the seal on my 47 torque tube without taking the race out. I knocked the old one out with a drift, then made a driver out of a long piece of pipe and a flat washer slightly smaller than the seal. I then put the seal on the tool with some grease so it didn't fall off, and pushed it all the way in and tapped the end of the pipe with a hammer to push it right into place. Then I followed the steps you outlined.
Bassman/NZ is offline   Reply With Quote
Old 03-29-2013, 06:35 AM   #5
Terry,OH
Terry,OH's Avatar
If you decide to install the bearing after installing the torque tube to the differental make sure you can get the bearing in place before bolting it up. I had one that would not go in after and had to remove the torque tube install the bearing and then reinstall the torque tube.
