07-23-2011, 07:39 PM | #1 |
53 cent oil leak fix
My modified B engine developed an oil leak so I cleaned all the possible sources and started the engine. Oil started oozing from the oil presure regulator. I took it apart and discovered a broken O ring. I replaced it with a new one from the hardware store. It's the least expensive oil leak repair I've ever had.
07-23-2011, 08:04 PM | #2 |
Re: 53 cent oil leak fix
Oil pressure regulator?
07-23-2011, 08:45 PM | #3 | |
07-23-2011, 10:57 PM | #4 |
actually i think its in the water pump ...............
V4f |
07-23-2011, 11:14 PM | #5 |
Glenn mentioned he had a MODIFIED B engine, so it may have had a different oil pump with a pressure relief to unload excess pressure.
07-23-2011, 11:28 PM | #6 |
07-24-2011, 12:36 AM | #7 |
07-24-2011, 12:38 AM | #8 |
Can you post a pic?
07-24-2011, 02:06 PM | #9 |
Hey Mike,
I'll try one later today. Right now have to go feed the ole folks and play for them(older than me!)... What do youse do in your "spare" time... |
07-24-2011, 10:41 PM | #10 |
Hey Mike,
Hereyeare. The large brass 'plug' that you see to the immediate left of the oil filter...is the oil pressure regulator. Pressure is reg by removing plug and changing to ...lighter or heavier spring..to decrease/increase oil pressure. BTW..it regulates pressure from a Stipe aluminum custom oil pump with hardened Chevy gears. I've got it set at 30lbs, but don't know if it even has a 'top' end pressure point. NOT a cheap pump, but the best? Last edited by hardtimes; 07-24-2011 at 10:43 PM. Reason: add...milton..see what you created! |
07-24-2011, 10:55 PM | #11 |
Thanks for the pics!!
07-26-2011, 12:40 PM | #12 |
Interesting information and I like the riley set up
07-26-2011, 02:15 PM | #13 |
Ray,
Well, it ain't 'exactly' the riley setup that I envisoned when I built this engine! The riley intake is the 'equalizer' chamber type, and the riley valve chamber cover is only one I've come across(full pressure filter attachment,etc). But, the Riley OHV iceing on the cake never came to be! Actually, any OHV setup would make this engine 'sing', but , at the time, ran out of funds for such. So the 7.1 flathead had to do. This NOS russian B block has a lot of the best equipment $ can buy, but sits there awaiting to be awakened. Hmm, thinking that a Stipe 3/4 cam would/could utilize some of whats (HP)available in this setup. Day dreaming for ole farts is fun too! Mabe put this one to sleep and installing the rebuilt '49 merc, 4"crank, that's been sleeping ! NAH! Going to keep searching for the OHV setup for this one. |
