Old 03-30-2019, 11:31 AM   #21
Solo_909
Default Re: 1951 mercury carburetor choke adjustment
Originally Posted by 51 MERC-CT View Post
To check one source of "stumbling". The normal position for the accelerator pump adjustment is the center hole on the plate. If it is on the center hole move the pin to the outer hole or if in the inner hole move one hole outwards. (use a screwdriver to pry away and drop into hole)
It’s on the center. Just for my knowledge what exactly does switching holes do to the acelerator pump?
Also why would it stumble only until I drive it hard and getting into higher RPMs and then clear up?
Solo_909 is offline   Reply With Quote
Old 03-30-2019, 11:46 AM   #22
rotorwrench
rotorwrench's Avatar
The photo shows an example of the dash pot mechanism used on Merc-O-Matics so it's a bit different than the manual transmission cars but not by much. The adjustment for the accelerator pump is a stroke distance adjustment. One way is more stroke and the other is less. You may also have a problem with the power valve vacuum actuator situated in the shroud housing of the carburetor. The vacuum is fed to it through a long circuit that can leak if the shroud fit is off or a gasket is leaking.
Old 03-30-2019, 12:05 PM   #23
Solo_909
Okay so I warmed up the car this morning and the choke plate does open slightly but...... when pressing on the throttle the choke step linkage never moves so when pressing on the throttle the idle doesn’t drop down. It also seems to run really rich with the jets only open 1/4 turn out. The choke plate does open when it’s warm but only maybe about 1/4” open. See photos first photo is of the car warmed up.
File Type: jpg B7514B8B-16BF-4FCD-87CE-88A648767C84.jpg (49.4 KB, 11 views)
File Type: jpg D0D43F20-C39E-415F-A273-92623FE7917C.jpg (49.3 KB, 7 views)
Old 03-30-2019, 12:54 PM   #24
51 MERC-CT
51 MERC-CT's Avatar
Based on your picture of the carb., it appears to have a'49 to early '50 carburetor installed with the choke up on the carb.
'50 and '51 had a divorced choke that mounts on the intake manifold.
It would be interesting to see if the hot air source is in fact hooked up to the correct intake manifold.
If the choke did not have a hot air source, the choke would not open.
Old 03-30-2019, 01:09 PM   #25
Solo_909
So it does have the correct intake for the choke tube and it does connect to the choke housing. I do need to take the tube off and see if it’s clogged up though.
Old 03-30-2019, 01:38 PM   #26
51 MERC-CT
51 MERC-CT's Avatar
It gives a little richer shot of fuel to compensate for the added air volume until a higher RPM is reached and a different fuel circuit takes over. {at least as I understand it )
Old 03-30-2019, 06:48 PM   #27
Solo_909
Gotcha,
So I’m sending the carb back to the guy who rebuilt it. Something just isn’t right with it. I set it maybe like 3 different times however the stumble wouldn’t go away. Plus once the car was warmed up when I would press on the gas pedal the idle would get higher not lower. Also when adjusting the choke plate using the black knob cover I had to turn it counter clockwise to shut the plate which is the opposite of lean.
I pulled the heat tube out and it seems clean and clear with no carbon build up so it wasn’t that.
Old 03-30-2019, 06:53 PM   #28
rotorwrench
Both my early 1951 cars have that type of carb. The date code is on top of the accelerator pump hump up on the air shroud. The divorced type came in later 1951 after the first of the year.
There are two tubes for the choke heat. One runs from the carb base down to the manifold and the other runs from the manifold back up to the thermostat chamber. It sounds like the thermostatic spring is not engaging the choke shaft or it's just not getting hot enough. A bad thermostatic spring may also be a cause. It's hard to say when you can't look at it.
Old 03-31-2019, 10:30 AM   #29
richard crow
there is such a thing called a choke pull off it,s a device that pulls against the choke butter fly by vacuum. is yours working
richard crow is offline   Reply With Quote
Old 03-31-2019, 12:27 PM   #30
rotorwrench
That's the little piston in the choke stove thermostatic chamber.
Old 03-31-2019, 09:53 PM   #31
Solo_909
No idea, I’m sending it back to the rebuilder so he can take a look at it.
