05-15-2013, 10:24 AM | #1 |
rattling fan pulley bearing
My 1928 truck has a rattling front bearing under the fan pulley.You can grab the fan and wiggle it excessively. Can i replace that bearing without having to take the whole front and radiator off. i ordered all new parts to replace the bearing, the felt and the washers, just not certain i can get the 4 blade fan off without having to dissassemble the radiator etc????
05-15-2013, 11:01 AM | #2 | |
Re: rattling fan pulley bearing
05-15-2013, 11:09 AM | #3 |
I have removed a pump w/4blade with bottom of radiator attached but the rods and top hose must be removed. Did this in the middle of the mojave desert so I may have had great incentive. you can buy dummy stud/bolts to make the job easier next time.
05-15-2013, 12:59 PM | #4 |
be very careful that before you tilt your rad forward you check to make sure that you remove your licence plate so the mounting bolts don't damage radiater.
05-15-2013, 02:13 PM | #5 |
That may be why I could do the job, my car doesn't run a front license plate.
05-15-2013, 03:15 PM | #6 |
So is the fan wiggling on the shaft or is the shaft moving? I bagged it all and went with an aluminum two blade fan and new water pump.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
05-15-2013, 04:34 PM | #7 |
Don't forget the cardboard to protect your radiator my coupe had a four blade on her without removing radiator i had a hard time with stock bolts on water pump.
