04-21-2019, 06:39 PM | #1 |
4" Merc crank & rods
I'm trying to figure out what a 4" stroke crank 2" rod journel
crank and matching set of rods are worth . Rods are standard and mains are -.020. Both are in good shape for reconditioning . |
04-21-2019, 11:36 PM | #2 |
Re: 4" Merc crank & rods
Are you sure it hasn't been stroked to 4 1/8 with those 2" rod journals? Which rods do you have?
04-22-2019, 03:45 AM | #3 |
As stated if it does have a 4 inch stroke with a 2 inch rod journal it is most likely stroked.
As I recall all stock cranks with 2 inch rod journals were 3-3/4" stroke (including Mercury) Last edited by 34PKUP; 04-22-2019 at 07:32 AM. |
04-22-2019, 04:22 AM | #4 |
It may be a scat or an Eagle 4 in one with the 2 in rods,
Lawrie |
04-22-2019, 09:06 AM | #5 |
Maybe there are 2 different cranks? One a 4" stroke and a different one with 2" journals??
04-22-2019, 09:47 AM | #6 |
04-22-2019, 12:24 PM | #7 |
I'll get some picts posted. Def. a old Ford crank
04-22-2019, 01:18 PM | #8 |
Pictures may or may not help but why not re-measure the stroke just to confirm your initial findings?
04-22-2019, 01:46 PM | #9 |
I sold a std. Merc crank a couple of years age for $50 at a parts meet.
04-22-2019, 02:38 PM | #10 |
04-22-2019, 05:15 PM | #11 |
Hi all, The rods have B38 marked on 1 side and 91 over H4 on the other
side of beam. The #2313 is on a counterweight. It does not appear to be offset ground . I would measure the stroke but it's not easy without a block. I guess I'll put it on the lathe . The mains are only .010 under. Maybe it is a 3 3/4 crank ? Thanks for reply's''''''''''''''''''' RJ |
04-22-2019, 05:41 PM | #12 |
Measured stroke . It is 4" .SO ,, What are the crank and rods worth ????
04-22-2019, 05:41 PM | #13 | |
Here is a link to some information that should help: http://myflatheadford.com/identify-4...ry-crankshaft/ |
04-22-2019, 06:03 PM | #14 |
Thanks, Big help.
