Old 09-12-2019, 09:51 PM   #1
tommyleea
Default 53 Ranchwagon flathead motor mounts
Having a problem with my new motor mounts from MACS. First of all, the holes in the mounts don't quite line up with the holes in the water pumps. I guess I will open the holes up to make them work. Next, I went to install the nuts on the studs to make sure there would be no problem upon installation. Well, the original nuts won't go on. I installed them on my old mounts, and all went well, so the nuts are good. Could the studs on my new mounts be metric thread? Metric thread on a flathead has to be against the law. Has anyone else had problems with motor mounts on their flatheads? Thanks for any inputs.
tommyleea is offline   Reply With Quote
Old 09-13-2019, 12:15 AM   #2
RalphM
RalphM's Avatar
Default Re: 53 Ranchwagon flathead motor mounts
Are you sure you don’t need the U shaped adapters for the mounts?
It’s dark here or I’d go out and get a picture for you, does the engine sit at the correct height?
RalphM is offline   Reply With Quote
Old 09-13-2019, 04:12 AM   #3
tommyleea
My old mounts were toast. The new mounts have a U shape to them. Top part of the U has holes, and bottom part has the studs that go thru the frame. A standard nut won't go smoothly onto the stud. It may be the paint that is on the studs, but I don't want to mess it up. I believe it is just a one piece mount.
Old 09-13-2019, 06:23 AM   #4
flatheadmurre
flatheadmurre's Avatar
So is the spacing between the holes attaching to the waterpumps or the size off...or is it the location between waterpump and mount.
They need to be installed in the frame first and then you have to bolt them to the waterpumps...but if they are incorrectly manufactured i would send them back and get some from another vendor..
Old 09-13-2019, 09:18 AM   #5
tommyleea
The spacing of the holes is slightly off, and the threads of the studs seems to be metric, although I find that hard to believe. I planned on installing the mounts on the engine first, because the holes in the frame are elongated, and I would have room to maneuver the engine and set it in place. I purchased the mounts several months ago, and I don't have the boxes now. I will call MACS and get some more information. Thanks for input.
Old 09-13-2019, 09:39 AM   #6
19Fordy
19Fordy's Avatar
Post a few photos and answers will come forth.
Old 09-13-2019, 11:34 AM   #7
flatheadmurre
If i remember right the geometry of the bolts sticking out at an angle don´t let you mont them both to the pumps first...they won´t go into the holes in the frame even if they are slotted...one side you can have attached to the pump but not both...
Sadly MAC´s quality control is between bad to none nowdays so anything is possible...and when you call them even when you know other people have had the same issue...std answer is sold a lot and never had any complaints...
I wouldn´t modify them...if they haven´t got spacing and thread right what says they got the rubber part good...
Old 09-13-2019, 03:43 PM   #8
tommyleea
OK..I see what you are saying about the angles. Yes, I did call MACS, but not much help as you say.0913191410a_resized.jpg
Old 09-13-2019, 04:05 PM   #9
RalphM
RalphM's Avatar
Sorry, I was thinking of the different style mount.
Kinda like this [
Old 09-13-2019, 04:44 PM   #10
tubman
tubman's Avatar
Get some correct motor mounts. Why are you fooling around trying to make some inferior products work? Send them back and order some from some of the vendors recommended on this site.
I only order from "Mac's" as a last resort, and then only for their cheaper products that usually come from somebody else.
Old 09-13-2019, 08:26 PM   #11
paul2748
paul2748's Avatar
Mac's is now a scrub place, crazy shipping costs, usually inferior parts unless they come from the well known vendors like Carpenter
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-14-2019, 10:48 AM   #12
RalphM
RalphM's Avatar
I was thinking of these type of mounts. But it looks like you need to elongate the holes to the water pump as well. This may make it easier to put the mount in place first, then bolt to engine.
I would check the threads with a gauge, they are cheap, then if the right thread nut is still not going on, chase the mount thread with a die.
File Type: jpg 881B32B7-AB46-4403-9A75-FDBA8391067D.jpg (40.3 KB, 10 views)
Old 09-14-2019, 12:13 PM   #13
flatheadmurre
The motormounts on that picture is the std donuts...
The u-shaped piece of flatiron is to adapt mercury waterpumps to fit in a ford...and not a special type of motormount itself.
Old 09-14-2019, 01:26 PM   #14
tommyleea
FYI..I did verify today that the mount studs are indeed metric at 10 x 1.25. That has to be #12 on list. Thou shalt not use metric hardware on a flatty!!
Old 09-15-2019, 10:59 AM   #15
RalphM
RalphM's Avatar
Unless it’s a French flathead!
Old 09-15-2019, 12:00 PM   #16
flatheadmurre
Or the german flatheads with metric bearings...ouch what a headache...never again!!
Old 09-15-2019, 01:41 PM   #17
tommyleea
Well, in that case I guess I will use them.
Old 09-15-2019, 04:59 PM   #18
tubman
tubman's Avatar
Since you are in Missouri (the middle of the good old USA), I would suggest getting the correct mounts. You may thank us for it, but the next owner certainly will.
Old 09-16-2019, 08:21 AM   #19
tommyleea
Copy..I am going to call MAC's today and let them know about the error. Thanks to all for the info. New mounts are in my future.
Old 09-16-2019, 09:36 AM   #20
tommyleea
Just an update..I called MAC's today. Explained my issue. They told me that the remanufactured mounts are all metric. I'm sorry could you repeat that? Anyway, I told them to at least put a note in the product details stating such. So, as others have stated MAC's will be a last resort from now on. Thanks for all your inputs.
