Old 09-05-2019, 09:03 PM   #1
Clem Clement
Clem Clement's Avatar
Default split pins usage
Clem with another dumb Q.
Are there places where the split pins are used for other than holding something on? Like thrust support or end of travel pin?
Meaning why do split pins need to be so thick?
Old 09-05-2019, 09:08 PM   #2
19Fordy
19Fordy's Avatar
Default Re: split pins usage
Some folks call cotter pins "split pins".
Are you referring to a "roll pin"?
Old 09-05-2019, 09:51 PM   #3
Clem Clement
no: Cotter pins
Old 09-06-2019, 02:03 AM   #4
A bones
A bones's Avatar
They are available in different lengths and thicknesses. Usually to prevent things from coming apart, as you said. Not however where thrust is or friction is a factor.
Usually there is a washer involved to protect wear and tear.
If you are experiencing difficulty removing them from your axle shaft pick up a tool catalog and find a cotter pin puller. It's like an ice pick that got slammed in a door jamb. With the extra pointy end, one can catch the eyelet and leverage the bent b#**#*d right out of its hole.
For axles and spindles I always look for the longer ones. Easier to spread open, just cut away what you like.
Disclaimer: The best though is not having arthritis. ( Sorry Ryan )
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 09-06-2019, 08:48 AM   #5
Mart
Mart's Avatar
"It's like an ice pick that got slammed in a door jamb."
That's a great description right there.
Mart.
Old 09-06-2019, 09:01 AM   #6
RalphM
RalphM's Avatar
If you are sizing a cotter pin for a high vibration/movement area like a rod nut, make sure the pin fits tight. If loose it can wear and come apart.
RalphM is offline   Reply With Quote
Old 09-06-2019, 09:34 AM   #7
19Fordy
19Fordy's Avatar
Keeping the drip hole in the early Ford v-8 oil pan was a good use for a split pin.
https://www.fordbarn.com/forum/attac...5&d=1332214197
Old 09-06-2019, 12:35 PM   #8
Clem Clement
I forgot the drip hole fixer. Thanks
Old 09-07-2019, 08:44 AM   #9
Don
Don's Avatar
What do they call a pli that looks like a nail but with a split down one side that’s under tension when driven into a hole!!!!
DON P
Don is offline   Reply With Quote
Old 09-07-2019, 11:57 AM   #10
Jack E/NJ
Jack E/NJ's Avatar
A hard to pull out pin or nail. 8^) Jack E/NJ
Old 09-07-2019, 12:16 PM   #11
37 truck
Spring pin, SOME CALL THEM ROLLED PINS
37 truck is offline   Reply With Quote
Old 09-07-2019, 12:22 PM   #12
JSeery
JSeery's Avatar
Roll Pin.
File Type: jpg pdp_henny_penny_roll_pin_knob-hen16138.jpg (13.2 KB, 5 views)
Old 09-07-2019, 04:52 PM   #13
Don
Don's Avatar
Ok.....
DON P
Old 09-07-2019, 10:08 PM   #14
Phil Gillespie
Phil Gillespie's Avatar
Originally Posted by JSeery View Post
Roll Pin.
Here we refer to them as tension pins.
Phil NZ
Phil Gillespie is offline   Reply With Quote
