Old 03-23-2024, 06:41 PM   #1
1951 Ford F3
Default stock NOS fomoco valve springs on a 236 @.050 .355 lift cam
I am building a 4.125 by 3.312 stroker. It will have dual carbs with 43 main jets, and a delta 236 effective at .050 .355 lift cam. Something like a stock Merc cam. I found some NOS fomoco valve springs for $71 shipped. Should I use these or some ISKY g-185s.
speak up
1951 Ford F3 is offline   Reply With Quote
Old 03-23-2024, 09:36 PM   #2
flatjack9
flatjack9's Avatar
Default Re: stock NOS fomoco valve springs on a 236 @.050 .355 lift cam
Get a set of LZ springs.
Old 03-23-2024, 09:58 PM   #3
1951 Ford F3
who carries them
Old 03-23-2024, 10:24 PM   #4
Pete
Pete's Avatar
If you can shim the NOS springs up to 50lb on the seat without coil binding, you should be ok.
You are on your own with the cam.
Old 03-24-2024, 09:09 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
You can probably get some LZ springs from Mac VanPelt. He used to carry them all the time, but last time we chatted he was having some issues with supply. I checked his last ones out - they were good springs at a fair price.
Old 03-24-2024, 12:17 PM   #6
john in illinois
john in illinois's Avatar
If those are Stromberg 97 carbs ,043 jets are probably too small . Stock .045 jets are a good place to start.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 03-24-2024, 06:24 PM   #7
Bill OH
I agree with John - 43s to small- use 45s and I use a 71 PV. And LZ springs are good.
Bill OH is offline   Reply With Quote
Old 03-24-2024, 08:00 PM   #8
1951 Ford F3
I found some NOS stock springs from 1955 for $70 plus shipping.
There is so much room to coil bind That I could easily shim .060 to >080 and still have .080 to coil bind on a .355 cam.
Should I buy them?
Old 03-24-2024, 08:00 PM   #9
1951 Ford F3
I will do 44 then at 6000 feet
Old 03-24-2024, 08:01 PM   #10
1951 Ford F3
who carries good PV for Strombergs
Old 03-24-2024, 08:02 PM   #11
1951 Ford F3
thanks, finally someone who understands the relationship between installed height and shims.
