03-22-2021, 06:52 PM | #1 |
Trans Dipstick
Does anyone know the part number of the trans dipstick tube O-ring? Of for real o-ring specs? Mine is dripping. I don't think I need to drop the trans pan to change that do I? Anyone ever done this repair?
It was tough to find (pin-point), and the thig drips more than you would think. 57 Ford, with the Ford-O-Matic Last edited by Gene F; 03-22-2021 at 07:01 PM. |
03-22-2021, 10:49 PM | #2 |
Re: Trans Dipstick
you should be able to pull the dipstick with tranny in the car. take the tube to a home center and should be able to come up with an O ring to fit
03-23-2021, 07:56 AM | #3 | |
Re: Trans Dipstick
I have looked all over the MPC and cannot come up with either a PN or reference.
Here is an interesting thread regarding the ring - Quote:
There should be an A/T PARTS SUPPLY in your area. Maybe go to a large TRANS SHOP and they may have or can refer you to a source.
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
03-23-2021, 08:24 AM | #4 |
Re: Trans Dipstick
There is NO o-ring on a Fordomatic dipstick tube. The tube to pan seal is by flare connection.
03-23-2021, 09:01 AM | #5 | |
Re: Trans Dipstick
You know what is worse than just getting old (besides ugly)? Senility and CRS. Must be why I could not find a reference ...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 03-23-2021 at 09:09 AM. Reason: AD PHOTOS - AGAIN ADVANCED CRS |
03-23-2021, 10:03 AM | #6 | |
Re: Trans Dipstick
Good luck!
Kent — Round Rock, TX '56 F-100 | '56 Crown Vic | '57 Fairlaine 500 | '57 Thunderbird |
03-23-2021, 04:52 PM | #7 |
Re: Trans Dipstick
Wow, no wonder I could not find the part number. Glad I asked now. It's not dripping bad. I am the type that does not like to leave things to chance, so I will jack up that side of the car, and put it on jack-stands. Then I can pull it off, inspect it, clean everything, and make a good attempt at getting in on right.
Thank you so much everyone. |
03-24-2021, 07:56 AM | #8 |
Re: Trans Dipstick
Here is another ILL that may help -
I would think TEFLON THREAD SEALER would also be a good touch.
03-27-2021, 06:45 PM | #9 |
Re: Trans Dipstick
Thanks Kultultz
03-28-2021, 12:13 AM | #10 |
Re: Trans Dipstick
Well, you're welcome but the THANX! needs to go to Dominic (Post #4) as he is the one that woke us up.
03-28-2021, 12:06 PM | #11 |
Re: Trans Dipstick
Maybe clean and smooth the flare, thread tape may not help as the flare is the seal, metal to metal. It may be the leak is from the actual weld of the spud on the pan. Worse comes to worse you could use some fluorescent dye and ultraviolet lamp.
03-28-2021, 03:23 PM | #12 |
Re: Trans Dipstick
It could just have some crud in it, and/or be lose too. I bet it is something simple. Now that I know the lay-of-the-land, it's just a matter of taking it apart , cleaning every thing up, and putting it back together.
