Old 06-29-2020, 12:07 PM   #1
Daniel f
Default Help - Ford brake id
My Model A was converted to Hydraulic brakes in the 1970s I need to service and replace the rear drums and I need help identifying what they are? Please help ID.
Daniel f is offline   Reply With Quote
Old 06-29-2020, 12:11 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Help - Ford brake id
The front brakes look like 46-48 type
Old 06-29-2020, 12:15 PM   #3
Daniel f
Thank you. However, the photo is the rear drum.
Old 06-29-2020, 12:27 PM   #4
deuce lover
deuce lover's Avatar
The drum is 39-41. The backing plate looks like 39-41 also.It appears that someone put front backing plates on the rear.If they were rear there would be e-brake linkage in that assy.Are there E-brake cable tubes on those backing plates?
Old 06-29-2020, 12:29 PM   #5
cas3
no parking brake?
Old 06-29-2020, 12:32 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Yes, your photo is a REAR drum. It is a 1940 or 1941 REAR drum. That backing plate is also a 1939 thru 1941 REAR backing plate that has had the parking brake pieces removed, as well as removal of the grease guard. This picture shows how it should look. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-29-2020, 12:37 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
A 1939 DRUM would have the wide-five bolt pattern. Drum is 1940-'41! Look at the LONG guide at 9:00 o'clock on backing plate that parking brake lever moves behind. Front backing plates don't have that LONG guide. FRONT plate would have two short guides like the one at 3:00 o'clock. Parking brake parts have been removed from this 1940-'41 REAR plate. DD
T5 W/TORQUE TUBE
Old 06-29-2020, 12:44 PM   #8
Daniel f
Thank you everyone!
Old 06-29-2020, 01:04 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
These are 1939-1941 FRONT backing plates. Note both guide clips are short. DD
T5 W/TORQUE TUBE
Old 06-29-2020, 02:32 PM   #10
Don
Don's Avatar
These are Lockheed type brakes in case you need to lookup and see how to adj them,just went Thur this on my 35 conversion,,,a little hard to understand instructions at first but after doing one it gets easier,,. Looks just like mine ,39-41 exception have the E brake,,
DON P
Don is offline   Reply With Quote
Old 06-29-2020, 02:41 PM   #11
19Fordy
19Fordy's Avatar
V8: In your photo of the 39-41 (blue shoes) is one of the brake cylinders on backwards?
Old 06-29-2020, 02:50 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
No, but the shoes are on backwards on the plate on the right...the FRONT, RIGHT plate. As YOU know, BIG end of cylinder to front. LONG shoe to front....Lockheed brakes! DD
T5 W/TORQUE TUBE
Old 06-30-2020, 12:26 AM   #13
Marvin/TN
Send a message via AIM to Marvin/TN
It looks like the Drums on my 46 Ford coupe
Marvin/TN is offline   Reply With Quote
Old 06-30-2020, 01:57 AM   #14
V8COOPMAN
V8COOPMAN's Avatar
1946-'48 drum has FLANGE on outside of drum, like below! DD
T5 W/TORQUE TUBE
Old 06-30-2020, 09:19 AM   #15
Tim Ayers
Don:
Which or who's instructions did you use? I have an old Motors book that seems to explain it well, but always looking for other resources. I think I also have a copy of Rumbleseat's tips somewhere as well.
Will need to do all four of mine.
Thank you,
Tim
Old 06-30-2020, 09:25 AM   #16
rotorwrench
rotorwrench's Avatar
The innys came first as has been mentioned about the hubs. The outies came later but you can find mixes and matches on the old cars due to preference or expediency.
Old 06-30-2020, 09:31 AM   #17
Tim Ayers
I did just this. '42-'48 hubs/drums fronts and '40 hubs/drums on the rear. All four have '40 backing plates. I like the '42-'48 drums due to the ribbing and since it's a fenderless car, you'll see them.
