04-27-2019, 08:42 AM | #1 |
1951 Merc front brake plates
Ready to put new shoes on the front and noticed that a couple of the rub nubs are worn and one has a burr on the outside edge. Can these still be used?
04-27-2019, 11:20 AM | #2 |
Re: 1951 Merc front brake plates
The new shoes can hang up on those wear grooves.
You need to build up the worn spots and grooves with weld and then grind them flat. |
04-27-2019, 05:16 PM | #3 |
04-27-2019, 05:38 PM | #4 |
Welding it up should work fine.
04-27-2019, 06:14 PM | #5 |
04-27-2019, 06:21 PM | #6 |
04-27-2019, 06:34 PM | #7 | |
Should be no problem; but if you do not feel comfortable with the process, send them my way and I'll take care of it for you. |
04-27-2019, 06:42 PM | #8 |
thats a good offer rich, can i send a couple cars over to you and jeff? all kidding aside, its easy job, and i dont think you will find any new ones, and old junk yards are getting scarce, and then its a merc besides, better plan on fixing yours
04-27-2019, 06:59 PM | #9 |
I'll send you some pics. I guess my question is how much "pride" do the rub points need from the base of the inner plate?
04-27-2019, 07:04 PM | #10 |
04-27-2019, 08:14 PM | #11 |
I will post the photo Keith sent to me, little difficult to see much.
04-27-2019, 09:32 PM | #12 |
04-27-2019, 09:34 PM | #13 |
just like rich said, only worn on the outside. quick fix
04-27-2019, 09:42 PM | #14 |
No "pride", just flush with the inboard original surface.
04-28-2019, 08:59 AM | #15 |
This is one of those things that I use brass on. The brazed area seems to last longer than the original steel.
04-28-2019, 09:43 AM | #16 |
Easy fix but if you want an complete front brake assembly,including drums as a spare, I have the ones off my 51 Merc.
04-28-2019, 10:10 AM | #17 |
Fixed mine using Stellite weld rod to virtually eliminate possibility of wear.
04-28-2019, 05:40 PM | #18 |
Who knows how many years these old car have gone without any lubriplate being applied to those pads. Shade tree mechanics seldom ever applied anything to them when performing a brake job.
04-28-2019, 06:25 PM | #19 |
New photo to post for Keith. Appears to me there is a fairly small area that needs addressed (welded in and dressed down) right where the edge of the brake shoe rides.
07-11-2019, 08:43 AM | #20 | |
Finally getting to the brake plates. Do I cover weld the entire pad or just a bead on the outer edge? thanks hoffer |
