12-03-2017, 06:46 AM | #1 |
Ardun Heads
Does anyone know or understand why Ford did not continue
with the Ardun heads? I have not found any info on the net so far Best |
12-03-2017, 07:25 AM | #2 |
Re: Ardun Heads
12-03-2017, 11:53 AM | #3 |
Re: Ardun Heads
I doubt Ford had any interest in or connection with the ARDUN heads. There would be no practical reason to do so. The flathead was well outdated by then (1947), with its small bore and long stroke, three main bearing design. Cars were becoming heavier and trucks bigger. It made more sense for car companies to just design engines with more cubic inches (like the 337 Lincoln/truck engine) than go the expense of adapting an unproven, unreliable, complicated aftermarket setup.
12-03-2017, 01:32 PM | #4 |
Re: Ardun Heads
Please remember both Chrysler and Ford used hemi combustion chambers in WWII aircraft engines. Since England received the majority of the Ford result, called the GAA tank engine, there is a chance Duntov saw those chambers during the war. The GAA engine was far advanced for the time, some can see parts if the design well in to the 1970's.
12-03-2017, 02:00 PM | #5 | |
Re: Ardun Heads
12-03-2017, 03:33 PM | #6 |
Re: Ardun Heads
Ford did not enter the large truck market until '48 when they redesigned their entire truck lineup, coming out with the BIG Job F800's with the big Lincoln V8, making them trucks in lieu of glorified cars.
Bill.... 36 5 win cpe |
12-03-2017, 04:11 PM | #7 | |
Re: Ardun Heads
However there was no need to even consider the ARDUN conversion due to the fact the larger Lincoln Flathead solved the problem of more power and torque needed in the larger Ford trucks being built at the time.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-03-2017, 04:45 PM | #8 |
Re: Ardun Heads
Timing as they say, is everything. The C&T Ardun was really coming into its own right about the time that the flatheads were being overtaken by the growing number of overhead-valve engines coming from the OEs. The flathead faithful were still out there, as were the Ardun heads, but the heads became even scarcer.
To convert today with the new Ardun kit is $14K just for the parts with you supplying your own Flatty.
Nomad |
12-03-2017, 04:51 PM | #9 |
Re: Ardun Heads
Nomad |
12-03-2017, 06:44 PM | #10 |
Re: Ardun Heads
Some very good responses. In my own reading the need for more power came from
the English market and the "trash truck" Fords engine was not powerful enough so Ford contracted with Duntov to build the Hemi heads. Like was mentioned by others the 337 Lincoln was the answer.. I don't think any of the American Automotive companies had a OHV engine before 49. And of course the "Hemi" was first used by the "Pipe" car company of Holland in 1905.. Just seemed that a bolt on Hemi head would not change the engine market for that time Like many developments of the automobile, the facts are sometimes lost in time thanks for you input... |
12-03-2017, 08:47 PM | #11 |
Re: Ardun Heads
Chevy has had overhead valve 6's since 1928. I don't understand why Ford stuck with such an out of date flathead design!
41 woodie https://41fordwoodie.weebly.com/ |
12-03-2017, 08:54 PM | #12 |
Re: Ardun Heads
Believe it or not Chev had an OVH in 1917 Chev D series & it was a V8 https://en.m.wikipedia.org/wiki/Chevrolet_Series_D
Nomad |
12-03-2017, 10:25 PM | #13 |
Re: Ardun Heads
To the best of my knowledge, Ford didn't contract to build the Ardun and had nothing to do with it's design or production. The same is true of Chrysler and their Hemi that followed.
Plenty of folks seem to believe that the Ardun was the first Hemi design - therefore Chrysler must have copied it. This is very far from the truth - as a hemispherical chamber design goes back many decades before the Ardun heads were designed. In the end, the Ardun heads were a case of too little, too late . . . all the major US manufacturers were already heavily involved in their own OHV V8 designs, with Cadillac and Olds being the first to the table. Also, the Ardun heads were an aftermarket product from day #1 - so the chances of any of the Big 3 manufacturers picking up a product like this (regardless of capability) - was pretty much slim and none. Detroit was not waiting around for the Ardun to be built - they were heavily under way with their own designs by the time the Ardun was designed and manufactured (at least on the GM and Chrysler side of the business). |
12-04-2017, 01:21 AM | #14 | |
Re: Ardun Heads
12-04-2017, 07:47 AM | #15 |
Re: Ardun Heads
Furthermore overhead valves go way back and believe it or not Dusenberg used roller rockers in the early 20s.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
12-04-2017, 12:32 PM | #16 |
Re: Ardun Heads
Buick used overhead valves from day one.
12-04-2017, 12:33 PM | #17 |
Re: Ardun Heads
Myth's.. Some of which are so entrenched in people minds that they never seem to go away. As to why Ford stayed with flat heads, long after almost every manufacture, save Chrysler, had gave up on the side valve engine at least ten years earlier is most likely a matter of economics. The flat head Ford was a very reliable, inexpensive engine, ergo the SBC. Through out the life of Ford flat head, Ford made improvements to the design, maybe minor, but there were many, improvements, as we all know.
Overhead valve engines have been around since the early teens, Chevy had a V8 in 1917, Pontiac had one in '34, it only lasted a year and most of them were recalled by the Factory.. A lot of the big trucks, International for one, had huge overhead valve six cylinder engines in the 1930's. Several of the Nash engines of the '30's were overhead valve with dual spark plug ignitions..
12-04-2017, 02:46 PM | #18 |
Re: Ardun Heads
Don't forget Marmon's aluminum OHV V16 from 1931. Also, Cadillac had an OHV V16 in the early 30s. It then came out with a flathead V16 later in the 30s.
I dig coal, which provides motivation for EVs. |
12-04-2017, 03:41 PM | #19 |
Re: Ardun Heads
Don't forget the millions of Chevy "stovebolts" produced before 1949
12-04-2017, 06:06 PM | #20 |
Re: Ardun Heads
A sales brochure for the Ardun conversion of a Ford 24 stud flathead motor.
Bill Monzo |
