05-17-2013, 11:59 AM | #1 |
Lesson learned,splash aprons
Well after my body man rant, put the body on(no splash aprons thanks to the body man) now trying to slip them in between the frame and body.no fun. don't try this at home! put the aprons on FIRST!
05-17-2013, 12:42 PM | #2 |
Re: Lesson learned,splash aprons
Boy you sure are having problems. Hopefully that first cruise helps erase all these bad memories
05-17-2013, 12:45 PM | #3 |
take your time and be patient you'll get it
dont scratch the paint |
05-17-2013, 01:08 PM | #4 |
If you can place it sliding in, How can you put the bolts to hold them? These bolts are underbody I think?
Have you installed the frame welt? |
05-17-2013, 01:27 PM | #5 |
yes we had to mill 2 slots for the 2 ft bolts . tack glued the frame welt down before setting the body good thing or would have had more PROBLEMS.
05-17-2013, 01:47 PM | #6 |
The bodyweight only did I could not get it out!! |
05-17-2013, 01:53 PM | #7 |
Never removed my body (no room to do so) so i had to pull them out and replace them with body lifted half an inch with a bumperjack. Did seems a bit fiddly.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
05-17-2013, 02:42 PM | #8 |
I suppose it sounds intimidating at first but my roadster body has been up in the air more times than a barber's chair, sometimes with the body bolts out of the elevated side, sometimes just loose, and loose on the other side, and jacked up with a plank under a cross sill. I did it most recently to install new running board shields. the carriage bolt at the back end of the shield required very little clearance to install. granted I'm uber-careful where I put my fingers while the body is elevated.
05-18-2013, 05:12 AM | #9 |
I gave a pair of new splash aprons to a friend of a friend to paint. Went to pick them up only to find they painted the underside high gloss black and stone guarded the top side. I was speachless! They claimed they talked about what side to paint and never thought of looking for a picture or calling to confirm.
Dave A Jamieson Portland, ON Canada 1928 Tudor |
05-18-2013, 11:18 AM | #10 |
well we are now trying to put on the front fenders the support that holds up the fender seems to long any help? its a cast arm this is a late 1930 vicky
05-18-2013, 02:11 PM | #11 |
Try swaping right and left fender braces and see how they fit. I will say that my November 1930 Victoria has stamped fender braces. Stamped fender braces were first used on Model A's starting in April 1930 so I doubt the forged braces are original to your Victoria.
05-18-2013, 02:19 PM | #12 |
For someone on their 4th restoration, this one is kickin' your tail!! Did y'all prefit any of the sheetmetal prior to paintwork? I would like to see some pix to see if there is something obvious we can spot.
05-18-2013, 05:51 PM | #13 |
Thanks to all,goter done!! our friend jim called and was a big help.and yes brent 4th resto but over 30 years. we do forget a lot and thanks for your input.
05-18-2013, 06:57 PM | #14 |
Well, good. Here's to hoping the worst is behind you now and better days are ahead!!
