Old 08-03-2020, 03:15 AM   #1
Ray Balukas
Ray Balukas's Avatar
Default Engine issue
I have an 8BA stock rebuilt { Walt Dupont} engine. It has run great, and still runs great except for 1 issue which just started. Taking off in 1st and 2nd gear , and winding her up, high revs the engine cuts out . If I dont wind it up it runs fine, no issues in 3rd gear. I have changed the points and condenser and timed it. Any help here would be great! Kind regards Ray
Ray Balukas is offline   Reply With Quote
Old 08-03-2020, 04:37 AM   #2
RobR'35
RobR'35's Avatar
Default Re: Engine issue
Starving for fuel?
RobR'35 is offline   Reply With Quote
Old 08-03-2020, 06:11 AM   #3
Ggmac
How high are you reving it ? Im leaning towards fuel starvation .
Stock fuel pump ? How old ? Tank and lines in good condition ?
Old 08-03-2020, 08:40 AM   #4
G.M.
Valves sticking a little. Needs a dose of
Marvel Mystery Oil. G.M.
www.fordcollector.com
Old 08-03-2020, 06:14 PM   #5
Ray Balukas
I have inspected the fuel line which looks fine, stock fuel pump 6 years old with about 4000 miles on it.The tank is clean. The 1 thing I noticed when under the hood revving the engine and letting off there is bubbles coming from the top of the pump into the glass bowl. not sure this is normal , as I said it runs great as long as I dont get into it and drive normal. I'll try the MMO also. Thanks for the info guys Ray
Old 08-03-2020, 06:34 PM   #6
alanwoodieman
air bubbles? change bowl gasket or rebuild pump/check valves, there is an air leak or the check valves are not working correctly. do a volume check
Old 08-08-2020, 02:03 AM   #7
RobR'35
RobR'35's Avatar
Any results on this issue?
Old 08-08-2020, 03:18 AM   #8
frnkeore
frnkeore's Avatar
Air leak in the flex line, going to the fuel pump.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 08-08-2020, 05:06 AM   #9
nickthebandit
Why do you mention a Walt DuPont engine ? Your problem doesn't appear to be because of Walt DuPont's work. You seem to have a fuel delivery problem.
nickthebandit is offline   Reply With Quote
Old 08-08-2020, 06:26 AM   #10
cadillac512
cadillac512's Avatar
Probably so we won't question the engine build since most of us know Walt's stuff is done correctly. That eliminates a lot of questions!
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-08-2020, 07:37 AM   #11
Pat/Ohio
Pat/Ohio's Avatar
My 8BA was experiencing the same "cutting-out" at higher rpms and I replaced the vacuum advance canister. It ran great after that!
Pat
Pat/Ohio is offline   Reply With Quote
Old 08-15-2020, 06:10 AM   #12
Ray Balukas
I've been gone for a bit will get to looking at this soon. The reason I mentioned Walt was to state that it was a stock rebuild, and no other reason. Thanks Cadillac 512. Walt is the best
