Old 02-12-2019, 12:49 PM   #1
KCTA Chris
KCTA Chris's Avatar
Default 1939 COE speedometer cable
Anyone know the routing of the speedometer cable through the cab? I've looked in the Green Books and cant find a layout. Fixing a cluster of extra holes that need welded up and not sure if this went through the top of the doghouse, firewall or floorboard? Thanks!
KCTA Chris is offline   Reply With Quote
Old 02-13-2019, 10:34 AM   #2
KCTA Chris
KCTA Chris's Avatar
Default Re: 1939 COE speedometer cable
I also need to know the routing of the temp gauge tube to sending unit.
Old 02-18-2019, 03:46 PM   #3
KCTA Chris
KCTA Chris's Avatar
Bump for the week... looking for my COE owners.
Old 02-26-2019, 03:32 PM   #4
KCTA Chris
KCTA Chris's Avatar
Weekly bump... anyone?
Old 02-26-2019, 08:08 PM   #5
Sparky79
I dont have a COE but I do have a 1.5 ton there is what appears to be in the picture an inch and an eighth hole to the left of the clutch pedal right in the corner of the cab firewall and floor board meeting point. That's where the speedo came up through. Not sure if the coe has the same path or not.
Sparky79 is offline   Reply With Quote
Old 02-26-2019, 08:10 PM   #6
Sparky79
Also looks like it goes up about 12" from the hole and hits a hold down strap.
Old 02-27-2019, 01:30 PM   #7
KCTA Chris
KCTA Chris's Avatar
Thanks Sparky, I was looking down around the floorboard corners like my other Fords but no luck. Finding not a lot of COE guys around, at least not restored.
Old 03-10-2019, 05:53 PM   #8
COE Dan
Chris,
I have a '47 COE and I've never touched my speedo cable so off-hand I don't know how it's routed. I'll have to take a look and a few photos. Give me a day/two to do that.
The 38-39 COEs have slightly different gauges so I don't know if my info will be helpful.
Dan
COE Dan is offline   Reply With Quote
Old 03-11-2019, 08:24 PM   #9
COE Dan
Here's a picture of my 47 COE speedo cable coming through the firewall. It appears the cable routes over the top of the doghouse behind the dash, then comes through the hole seen here and follows the body contour down towards the transmission.
Caveat: My truck has a had a few mods but the dash cluster and the trans are stock so I don't think the speedometer cable is different than stock. It is possible that this isn't the correct location. Also, this may be accurate for a 41-47 Ford COE but perhaps not for a 38-40.
FordBarn wouldn't let me load a larger pic. If you need a larger version, PM me.
Hope this helps,
Dan
Old 03-14-2019, 01:04 PM   #10
KCTA Chris
KCTA Chris's Avatar
Dan- thank you!
I never would have thought they routed on the pass side, huge help!
FYI I'm in KC looking for a 2 speed rear and two extra (lock ring style) wheels. Any thing you find down your way for sale?
Old 03-17-2019, 02:17 PM   #11
COE Dan
Chris,
I'll PM you.
Dan
