09-24-2012, 03:04 PM | #41 |
Re: Very fine rust in gas tank-what to do?
Now is a good time to be grateful that you don't have a town sedan.
Steve |
09-24-2012, 10:41 PM | #42 |
When I cleaned my gas tank,I found that I could get a lot more rust from the tank if I removed the shut-off valve as the gas will run out faster thru the larger hole.You can use a stick to push a pile of rust over to the drain to get more out.
09-25-2012, 12:00 AM | #43 |
Fred, Build what you see in my Photo, out of 1/4 Pipe fittings. It works for Me, with just a Glass Sediment Bowl on the firewall. I have a fairly clean tank, but still get a few rust particles when I drain the Sump Nipple. Would save you a lot of time Taking apart your cleaning system as your trying to do now.
09-25-2012, 01:48 AM | #44 |
I know of 2 cars with really crummy tanks, but with the addition of the stainless standpipe filter in the top of the shut off valve, they never have any problems. Bill W.
09-25-2012, 09:47 AM | #45 |
Fred,
Not sure just how you are going to solve the problem with your rusted tank but maybe send it to Brent Terry...he does some great work on taking those tanks apart, cleaning them up, and reassembling them. Just a thought. Pluck |
09-25-2012, 11:49 AM | #46 |
Fred Kroon 1929 Std Coupe 1929 Huckster |
09-25-2012, 02:15 PM | #47 |
I use phosphoric acid in similar applications. You would have to remove the tank though. That way you can allow it to work in all areas of the tank and empty and flush easily. I have used it on gas tanks before, so I'm confident. I use it on sheet metal as well. Again, if you are interested in removing the tank, this would be the option I would use.
Pete's Ponies Mustang RUSToration & Performance |
09-25-2012, 04:20 PM | #48 | |
09-25-2012, 04:29 PM | #49 |
Well I got the tank out of the car. Wow what a job. Most of the old bolts twisted off. I would guess they were the original.
I washed the tank out with a little gas and dumped it out the fill hole. Got a lot of rust flakes out. Called a few local radiator shops. One will do a job similar to what Pluck mentioned above. So will have to choose which way to go now.
09-25-2012, 05:10 PM | #50 |
I think I would have tried flushing it with water a few times and see if that helped before removing it. JMO Paul in CT
09-25-2012, 09:37 PM | #51 | |
Couple this with the tendency of the average Model A owner to do it themselves, and you can see where this leads to. However, were it me, I would avail myself of the radiator repair shop approach. For one thing, I believe the HCl-do-it-yourself approach would involve trying to slosh around whatever quantity of acid you use in a gas tank that – according to How To Restore Your Model A Ford, Volume 5 pages 10—13 – already weighs about 43 lbs. For another thing, there are three holes that ought to be sealed in order to safely clean the tank with acid; the gas outlet is easy to seal but the gas gage and filler neck represent an entirely different – albeit not insurmountable – challenge. Then there is the question of what to do with the residual HCl (although as Dr. Renchler, site chemist at a reactor facility I worked at - at the Idaho Nuclear Engineering Laboratory - used to point out, if your strawberries aren’t doing too well, add a little acid to the soil, except that I seem to recall his acid of choice was nitric acid). Bottom line: seems the cost-benefit of doing it yourself – and the potential downside of an “embarrassing moment” - argues towards letting the professionals do it in this case. As an aside, if you have a dull file, one quick-and-dirty method of restoring some cutting edge to the teeth is to soak the file in muriatic acid for a couple of hours. Rinse well, spray with oil so it doesn’t immediately rust, and add the acid to your strawberries. And for those of you with swimming pools, I share your pain. Having grown up in the south (San Fernando Valley) I always thought a swimming pool was a staple of life. Well, it is a staple of life (as in “it’s with you every day of your life”) although the severe weather in Napa limits its use. Why just last winter it got so cold here that we had to turn on the pool heater…
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. |
09-25-2012, 09:48 PM | #52 |
Thanks Skip for the heads up on muriatic acid. After thinking about it, much like you described, I to think I will use another method to clean this thing. I ordered some Bill Hirsch Cleaner which is bio-degradable and I have used before on another tank in my huckster.
I did called around to a number of radiator cleaners here in this area and most of them did not want to do a "boiling out" of a gas tank. There was one chain company that would do it for about $200 and put a sealer in it also for about $350.
09-26-2012, 01:24 PM | #53 |
Phosphoric acid is much easier to use. It is commonly used in rust removal in bodyshops. It isn't as dangerous to work with. It also leaves a coating behind, which is a good thing. There are so many ways to use it though, depending on what you want to do. It is available at Home Depot as a concrete cleaner. Or, pay a lot more and get it through DuPont as a metal prep . . be smart and save money. I leave it in gas tanks for a few days, moving the tank around. Then pour it out and flush well. Most times, that is all that is needed and no loose material ( rust ) will be left in the tank. I did a Harley tank most recently and then coated the inside with Master Series, which is a moisture cured urethane that is impervious to fuels. Not that it needs to be done this way all the time. I wipe down bare sheet metal with phosphoric acid prior to coating with epoxy primer. I keep some full strength in a jar and put nuts and bolts in it for a few days. They come out blackened, ready for paint or left alone to match some factory finishes.
09-02-2015, 01:31 PM | #54 |
Drain the tank and use a mechanic's magnet with flexible handle to pick up the rust !! Works like magic!! No need to remove tank!!
09-03-2015, 08:36 PM | #55 |
Im glad to find this post. I too have been fighting the same rust issues. I am about to the point of pulling my tank to have it cleaned and relined. I just want it to end with the filter plugs and road side clean outs. as one member has mentioned a stove pipe in bottom of tank, no luck with this fine power rust. Im going to hate to do what needs to be done and pull the tank. I am thinking once an done.
09-03-2015, 09:07 PM | #56 |
Phosphoric acid is best. I've done both muriatic and phosphoric and the phosphoric works much better. Muriatic will cause more rust.
Here's a good source... http://www.finishing.com/336/11.shtml |
09-03-2015, 10:36 PM | #57 | |
I would fill the tank slosh is around real good and let it sit a day. I would then drain a little (gallon or so) and see what you get. Filter add back to tank. Stabil 360 is supposed to help with tank corrosion even above the fuel line as well as keeping fuel fresh. That is what they advertise anyway.
09-04-2015, 07:06 AM | #58 | |
I have asked this time and time again (....and here we go again! ) but when you guys put in the acid to 'eat the rust', that is great with the exception that the de-rusted metal inside the tank is bare now. What happens to bare metal? ( I can also tell you that sloshing a tank only seals a portion of the tank's metal. The rest is left exposed to re-rust again. ) |
09-04-2015, 07:13 AM | #59 |
Well, since the thread was started 3 years ago, why dont we just let Fred tell us what he did to fix the problem?
09-04-2015, 12:35 PM | #60 | |
