09-03-2014, 11:02 AM | #1 |
Gas resistant paint for tank?
I want to spray (rattle can if possible) my gas tank before putting it back in place. Is there a rattle can 'black' that will withstand some gas spillage? Possibly Tractor Supply or similar outlet?
09-03-2014, 02:53 PM | #2 |
Re: Gas resistant paint for tank?
try some appliance epoxy. I think I seen gloss black, gloss white, satin stainless in wally world.
09-03-2014, 02:56 PM | #3 |
Acrylic enamel with hardner worked for me.
09-03-2014, 04:16 PM | #4 |
An epoxy would probably be the most durable
49 Mercury M68 Pickup |
09-03-2014, 05:22 PM | #5 |
If there is alcohol in the gas good luck.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. |
09-05-2014, 09:03 AM | #6 |
09-07-2014, 02:13 PM | #7 |
Do what Ford did. Use lacquer to paint the tank. It is fuel proof. Ford found that out when the gas tank was cowl mounted on the Model A where overfilling and ripping was a sure thing.
09-07-2014, 02:14 PM | #8 |
Use lacquer. It is fuel proof. Ford discovered that when the filler on the Model A was put into the cowl.
09-07-2014, 03:06 PM | #9 |
Powder finish...
09-08-2014, 12:35 AM | #10 |
If Du Ponts IMRON is still available it will hold up brake fluid won't even touch it from what I have heard but it isn't in a rattle can
09-08-2014, 01:02 PM | #11 |
We buy lacquer in rattle cans for use on parts exposed to gas.
