11-09-2012, 11:05 AM | #21 |
Re: Understanding the "load-a'matic" distributor
Lets try this one :
http://s103.photobucket.com/albums/m...t=100_8914.mp4 Note the progression of advance with rpm change at the end of the video. Every time i increased the rpm the advance curve moved a few degrees. A good example of a good advance curve with mechanical weights and springs. |
11-09-2012, 07:49 PM | #22 |
Bubba, I have a '55 Tbird with the load a magic with the tach drive. Can you convert it to centrifugal and retain the tach drive? Thanks. Rod
11-09-2012, 08:20 PM | #23 |
Bubba, I have a '55 Tbird with the load a magic with the tach drive off the distirbutor. Can you convert it to centrifugal and retain the tach drive? Thanks. Rod
09-16-2021, 01:02 PM | #24 | |
Would you (or anyone here) have the advance curve specification for the original '49-'53 flathead V8 load-a-matic vacuum-only design, please? |
09-16-2021, 02:49 PM | #25 |
Although this is from Mercury manual it should be the same.
09-16-2021, 02:55 PM | #26 |
