Old 10-01-2019, 05:44 PM   #1
30aadoodlebug
30aadoodlebug's Avatar
Default Unibody on a 49-50 Ford Woddie the same???
Hey all,
I just landed a sweet donor car for my restoration of my 50 woodie. I only need the main body. Heres the issue: the donor is a 49. All of my research says that the main bodys are the same for the two years.
Thanks
30aadoodlebug is offline   Reply With Quote
Old 10-01-2019, 05:55 PM   #2
tubman
tubman's Avatar
Default Re: Unibody on a 49-50 Ford Woddie the same???
What did the donor frame come from? From what I know, convertibles and woodies had frames that were different from regular passenger cars. That being said, if there is anything left of your original frame, you may have the pats required to bring a "non-woodie" frame up to snuff.
Old 10-01-2019, 06:03 PM   #3
30aadoodlebug
The donor has the same ladder frame style as mine. From my research, the only real difference is the front end of the body; ie, fenders, grill, and emblems. I have all those off the other two 50's I'm using to put this car in decent shape. No bondo other than a skim you can read the newspaper through. a patch panel here and there. Thats my plan.
Old 10-01-2019, 06:04 PM   #4
30aadoodlebug
The donor is a 49 woodie
Old 10-01-2019, 06:09 PM   #5
V8ER
Is your '50 woodie an "early" (wood tail gate/three quarter windows) or "late" (steel tail gate/two quarter windows)?
V8ER is offline   Reply With Quote
Old 10-01-2019, 06:23 PM   #6
30aadoodlebug
Late
Old 10-01-2019, 06:24 PM   #7
30aadoodlebug
December 50, built in Chicago.
Old 10-01-2019, 06:37 PM   #8
V8ER
Proceed carefully. Measure, measure and remeasure. The windshield area, quarter window area, tailgate, and tailgate latch area are different. The '49 had mahogany panels and the late '50 had steel panels so those areas are different. The '49 and '50 had different sill plates and different hood hinges with different mounting. Some '49s had wood headliner bows.
Old 10-02-2019, 05:30 PM   #9
30aadoodlebug
V8er,
I have done my homework as far as the hood is concerned. I have the front end of the 50 which the hood mounts to. In measuring the tail gate. I measured a 49 compared to a stock 50, and they line up just right. I do know for the hinges on the hood I need to tap a new hole on the side wall.
Old 10-03-2019, 06:38 AM   #10
Juergen
The 49 doors had different latches which were junk and quickly changed in 50
Juergen is offline   Reply With Quote
Old 10-03-2019, 07:18 AM   #11
Frank Miller
Frank Miller's Avatar
I know that is true for cars but I think the woody had mercury hardware so that might be different.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 10-03-2019, 08:04 AM   #12
nelsb01
nelsb01's Avatar
Yes the main woodie bodies are the same. The tailgate is the only part that can be different -- wood insert or metal stamping. Now there are other small differences -- the door handles (1949 Mercury handles in 1949-push button in 1950), front fender spears were different, and you know about the rear side windows, the grille, front bumper, and parking light differences. I believe that only the very early 1949's had the wooden interior bows. The dashboard was also different. 1949 was birch woodgrained and I believe that 1950 was oak wood grained. There are also the dashboard trim that is different. But -- the dashboard size is the same so you can remove one and install the other.
As for the frame -- starting with job 1, 1949 Ford and Mercury woodies had the convertible X frame. Sometime in 1950 Ford realized that the ladder frame was strong enough and it was subsituted into production.
Part of Ford's marketing plan for 1950 was "50 ways better". Most of that pertained to the front suspension, so the 1950 frame would be the one you want to use.
nelsb01 is offline   Reply With Quote
