06-08-2018, 08:29 AM | #1 |
Tool indentification
Looks like a honing tool but???? Like to know what this tool is used for. B D Ballantine Mfr. Fitchburg, Mass. Pat Applied. .. Last edited by Joop; 06-08-2018 at 05:08 PM. |
06-08-2018, 09:34 AM | #2 |
Re: Tool indentification
Hard to imagine the size of those puppies, maybe stick a ruler in one of your pix.
Corley ----------------- Subscribed to the KISS principle! |
06-08-2018, 12:29 PM | #3 |
Maybe valve grinding gauges,
06-08-2018, 02:50 PM | #4 |
Looks like it could possible be a specific purpose made holder for dial indicators for performing shaft alignment using the reverse dial method.
06-09-2018, 07:52 AM | #5 |
Since I can't figger it out, I "probably" don't NEED it!---"IGNORANCE IS BLISS"--Whatever thet MEANS???
Bill Simpleton
06-09-2018, 08:44 AM | #6 |
06-09-2018, 02:27 PM | #7 |
briphaeton has it correct. you place your valve in the fixture bump the bottom edge to your valve, transfer this to the drop in dummy valve and on your valve grinder set the dummy against the stem grinding wheel( wheel stopped) and dial back the clearance on the valve grinder.
06-09-2018, 05:10 PM | #8 |
Yup, that's it. A low tech version of the micrometer version, that will work with mushroom stem valves.
06-10-2018, 07:53 AM | #9 |
But now you know what it's for, so now you need it! Good news, another new tool on the shelf! But wait, do you need a Sioux valve grinding machine to go with it? Yes, I think so, and those are big. Got one to sell you though...
06-10-2018, 10:48 AM | #10 |
I plan on making them.
06-12-2018, 01:38 PM | #11 |
I think we are trailing away from the question.
Thanks for pointing me in the right direction. If someone is interested in this tool please contact me. Thanks |
06-12-2018, 11:48 PM | #12 |
06-13-2018, 07:55 AM | #13 |
Nooo we dont do that here. might wanna stick a tag and label them as such on them.
