03-12-2018, 11:10 PM | #1 |
Rod knockin'
I have developed a rod knock. Time to pull the pan and see whats happening. Hopefully the crank isn't damaged. That would open a big can of worms. I guess that answered my question whether my engine had poured or inserted bearings.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
03-12-2018, 11:18 PM | #2 |
Re: Rod knockin'
How does a rod knock determine insert or poured?
03-13-2018, 02:00 AM | #3 |
Re: Rod knockin'
How was it determined whether it was a rod, piston slap, or wrist pin?
03-13-2018, 01:36 PM | #4 |
Re: Rod knockin'
Previous experience.
03-14-2018, 08:43 AM | #5 |
Re: Rod knockin'
Ifn it just started knocking and isn't too loud yet the crank should still be good.
03-14-2018, 12:06 PM | #6 |
Re: Rod knockin'
03-14-2018, 02:43 PM | #7 |
Re: Rod knockin'
A rod knock is most noticeable on deceleration.
03-14-2018, 03:34 PM | #8 |
Re: Rod knockin'
What do you know about the engine. Did you rebuild it or is it an unknown used engine. Could be a ton of things. I am thinking piston slap right now. How much compression do you have?? If you have decent compression it could be wrist pins.
03-14-2018, 09:47 PM | #9 |
Re: Rod knockin'
When I bought the car I pulled the head and replaced it with a 5.5. I noticed 4 new pistons and 8 new valves with very little carbon. That is all I know about the engine. Idle and low RPM is fine anything above that results in loud clatter.
03-14-2018, 10:15 PM | #10 |
Re: Rod knockin'
I'll take a stab, how about a broken valve spring (Using ESP). BTW how was it running noise-wise before the head swap? Maybe it is time to drop the pan for a look-see. Pulling the pan is always a good idea for any engine you or any new owner is not intimately familiar with.
03-15-2018, 01:32 AM | #11 | |
Re: Rod knockin'
03-15-2018, 01:58 AM | #12 | |
Re: Rod knockin'
Same symptoms my 29 had when I bought it. My center main was totally gone. All the babbit was in the bottom of the pan. |
03-15-2018, 06:54 AM | #13 |
Re: Rod knockin'
Sounds like a center main to me also. It does not sound like a rod.
03-15-2018, 11:45 PM | #14 |
Re: Rod knockin'
I guess I'll find out when I pull it down. :-(
