02-13-2023, 07:30 PM | #1 |
Universal Torque Values
Is the a published list of torque values for the universal joint bolt and the clamshell bolts? I didn’t see anything in the Les Andrews book or in forum search.
Sent from my iPhone using Tapatalk Last edited by shew01; 02-13-2023 at 08:38 PM. |
02-14-2023, 11:41 AM | #2 |
Re: Universal Torque Values
Depends on size there is a Bolt-Grade Torque comparison in Les Andrew Book-A4. If your looking for Torque amount No, Tight till you feel ok with it.
www.whidbeymodelaclub.com |
02-14-2023, 11:48 AM | #3 |
Don't forget that those bolts have castellated nuts and cotter pins. I would go "moderately tight" then continue until the holes line up for the cotter pins. There's no particular stress on those bolts.
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
02-14-2023, 01:26 PM | #4 | |
The one I’m really concerned about is the universal joint bolt. I don’t want to get it too tight and crush the washer or leave it too loose and risk the bolt coming free again and flying around in the clamshell cavity. I’m looking for the Goldie Locks “just right” torque. [emoji4] Sent from my iPhone using Tapatalk |
02-15-2023, 04:01 PM | #5 |
I thought I would check one more time. What torque should the universal bolt have?
02-15-2023, 04:05 PM | #6 |
02-15-2023, 05:07 PM | #7 |
Locktite thread locker is good insurance. It can be medium grade or heavy if you choose. Just make sure the threads are clean.
02-15-2023, 07:24 PM | #8 |
I cleaned it with mineral spirits.
02-15-2023, 07:24 PM | #9 |
And I used a thread locker.
