Old 04-17-2020, 06:40 PM   #1
ahshoe
Default Which PS fluid
I have a new rebuilt Eaton power steering pump and all new power steering stock items under my 61 Galaxie. Question : I have 2 different ATF quarts on my fluid shelf. I know both are for older Ford "automatic" trans. One says Type FA other says Type F. Which one should I use for my new Eaton PS system. Or is there no difference?
ahshoe is offline   Reply With Quote
Old 04-17-2020, 10:38 PM   #2
KULTULZ
KULTULZ's Avatar
Post Re: Which PS fluid
TYPE F fluid was not introduced until the 1968 model year. Original spec most likely called for TYPE A/TYPE A SUFFIX A which has evolved to DEXRON III.
Did the REMAN say what fluid to use?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 04-22-2020, 06:36 AM   #3
oldbugger
oldbugger's Avatar
Default Re: Which PS fluid
1968? really learn something new ever day
oldbugger is offline   Reply With Quote
Old 04-22-2020, 06:42 AM   #4
KULTULZ
KULTULZ's Avatar
Well technically, 1967 as it was intended for use in the 1968 models.
Old 04-22-2020, 11:40 AM   #5
Ole Don
Ole Don's Avatar
The system is so simple, I would think any clean ATF would work. If my memory serves me, I think my 55 with stock P/S has a little of each.
Ole Don is offline   Reply With Quote
Old 04-22-2020, 06:28 PM   #6
KULTULZ
KULTULZ's Avatar
Cool Re: Which PS fluid
OP,
I don't think I would throw just anything into a PS SYSTEM, especially freshly rebuilt. There are different lubricity and additive package requirements.
Both ATF and PS fluid for this period was TYPE A - SUFFIX A. It has been upgraded (design progressions) many times over the years.
Old 04-22-2020, 08:32 PM   #7
ahshoe
Now I am more confused....type F or type FA.Anybodh just fill a nee Eaton pump Ford 60's system
Old 04-23-2020, 02:33 AM   #8
KULTULZ
KULTULZ's Avatar
DEXRON III or any GM SUGGESTED REPLACEMENT FOR DEXRON III
Buy it fresh and make sure the refiner has a license from GM - listed on bottle) to offer the correct fluid.
I never figured out what TYPE FA was.
FORD went to MERCON V and pulled the license for any previous MERCON oil. MERCON V is a synthetic blend and is suggested for all previous MERCON applications.
Be careful of imitations.
Old 04-23-2020, 06:19 AM   #9
oldbugger
oldbugger's Avatar
Sooo, dextron III and type A are compatable?
Old 04-23-2020, 08:28 AM   #10
KULTULZ
KULTULZ's Avatar
TYPE A was discontinued decades ago. Progression development over the years has resulted in DEXRON III (GM) as the service replacement.
MERCON (FOMOCO) unique to FORD applications has resulted in MERCON V, a partial synthetic, called out for all previous MERCON applications.
Rule of thumb- TYPE F can be used in early GM DEXRON(S) application(s) but not visa-versa.
It is even more confusing now as TRANS are sourced from all over the world and require their own unique lubricants.
Old 04-23-2020, 01:41 PM   #11
KULTULZ
KULTULZ's Avatar
Maybe this will help understanding FORD ATF -
https://en.wikipedia.org/wiki/MERCON..._%22A%22_Fluid
Old 04-25-2020, 09:10 AM   #12
ahshoe
I still hate to put the newest available PS fluid like Mercon V in a 1961 stock (rebuilt and NOS parts) system. So with what I have new quart wise on my shelf from awhile back are Type F and type FA...with that in mind which of these two would be best for my system?
Old 04-25-2020, 10:25 AM   #13
KULTULZ
KULTULZ's Avatar
Unhappy Re: Which PS fluid
Neither. How old is that oil?
DEXRON III (GM based) is the replacement. The only current use I know of for TYPE A (and this used whale oil until the use was outlawed) is for a gear box on certain bikes.
I can't help you any further. Maybe someone else can help you. Ol' Don had the answer, just dump anything into it.
Old 04-25-2020, 02:02 PM   #14
ahshoe
Thought anyone?
Old 04-25-2020, 03:28 PM   #15
39deluxecp
39deluxecp's Avatar
IHC hytrans fluid
39deluxecp is offline   Reply With Quote
Old 04-26-2020, 12:21 PM   #16
rotorwrench
rotorwrench's Avatar
Type F and Type FA are the same specification. Power steering likely won't care what's in there like a transmission would but I hesitate to mix ATF types. If it had type F (FA) then it would be wise to keep it that way unless it is completely drained. If the system is empty then you can use any type that is available to you.
Old 04-26-2020, 12:51 PM   #17
KULTULZ
KULTULZ's Avatar
Question Re: Which PS fluid
On what do you base this claim?
Old 04-26-2020, 06:17 PM   #18
KULTULZ
KULTULZ's Avatar
FA - FORD AUTOMATIC and POWER STEERING FLUID - PART NO. C1AZ 19582-A, C, D
FORD OIL AND LUBRICATION GUIDE - VOL 69-ST-15
(A-B-C-D) were TYPE A SUFFIX A FORD SPECIFIC blend progression in 1959-1960 - All were TYPE A)
In 1959, FORD blended it's own version of GM TYPE A SUFFIX A. I think it was called FA (I never saw that description) to differentiate it from GM TYPE A - SUFFIX A. Final version was D for the 1961 model run.
There was also an FA released in 1980 or thereabouts for the C5. It was backwards compatible with TYPE F but did not replace it as you can still buy it from FORD today.
EDIT -
The above statements are not correct. Please ignore. Source not verified.
I see FA on independent refiners packaging (and didn't pay any attention to it) but never saw it on FORD packaging.
While researching this, I came across some of the strangest stories and claims imaginable.
I hate 'OL WIVES TALES ... They just keep on going ...
Old 04-27-2020, 12:29 PM   #19
KULTULZ
KULTULZ's Avatar
(A-C-D) were TYPE A SUFFIX A blend progression in 1959-1960 - All were TYPE A)
OK, got to wondering and what I read in the LUBRICATION GUIDE was explained in a footnote, KEY TO LUBRICANTS.
FA - FORD AUTOMATIC TRANSMISSION and PS FLUID.
Another example - ST - STANDARD TRANSMISSION LUBRICANT and so on.
FA does not stand for a type of fluid, at least in FOMOCO terminology.
I have seen on aftermarket fluids the description FA and I am now a$$-u-mine(ing) is just is a description of FORD AUTOMATIC.
Old 04-27-2020, 12:11 PM   #20
rotorwrench
The first time I ran into type F/A I was thinking, what the hell is this, so it checked further and it is a conglomeration of variations of the Type F. Type A and Type F are and have been considered obsolete for some time and as such, they are no longer regulated. In other words, you can mark them however you want to if your in the business of marketing ATF unless someone has a trademark on the type. I think it's an iteration of type F and type A grafted together but I can't prove anything since few even show the Ford specification numbers on them any more. They can avoid trademark infringement problems if they change the lettering.
The type F was developed as a high friction fluid for Ford transmissions that were manufactured before a certain date (replaces type A and type B) or those that have the ESW-M2C33-F spec stamped on the dip stick. It works well in certain type fluid pumps too. Any Ford transmission that has metal clutch plates can benefit from having a fluid with high friction characteristics. Some drag racers like to use it for harder lock up on launch in any transmission from GM to Mopar.
