Old 03-31-2020, 01:03 PM   #1
adamsford40
Default window glass in a 1940 ford coupe
trying to replace a cracked glass on my 1940 ford deluxe coupe door. I have the garnish molding off, door and window handles off, the upholstery off, and don't know how to get the window out of the door. Hanging on the bottom stop. Need some tips on how to get the glass out.
Thanks,
Marshal Adams
adamsford40 is offline   Reply With Quote
Old 03-31-2020, 03:37 PM   #2
TJ
TJ's Avatar
Default Re: window glass in a 1940 ford coupe
Lower the unit with the regulator attached to the bottom of the door Remove the regulator, turn the glass 90 degrees and you can lift it out through the top.
Old 03-31-2020, 06:38 PM   #3
Kube
Kube's Avatar
I find it easier to R&R the glass from the bottom of the door. I've restored six, (seven?) coupes to date and have done each one that way.
Old 04-01-2020, 10:10 AM   #4
TJ
TJ's Avatar
Mike you are correct on the coupe. I was thinking the about the glass in a pickup for some reason.
