02-14-2018, 09:52 PM | #1 |
zenith carb
I have a zenith carb that for some reason does not have threads in the secondary well hole to screw the brass secondary well fitting into. Is that a normal carb or is it some kind of mistake?
02-14-2018, 10:22 PM | #2 |
Re: zenith carb
02-14-2018, 10:31 PM | #3 |
Re: zenith carb
https://www.macsautoparts.com/ford_m...dary-well.html
Is this the secondary well pf which you are referring? |
02-14-2018, 11:05 PM | #4 |
Re: zenith carb
Yes that is the part
02-14-2018, 11:44 PM | #5 |
Re: zenith carb
You have an early 1928 carb.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
02-14-2018, 11:48 PM | #6 |
Re: zenith carb
www.whidbeymodelaclub.com Last edited by Gary WA; 02-15-2018 at 05:24 PM. |
02-15-2018, 12:43 AM | #7 |
Re: zenith carb
I know nothing about the past on this carb. I came by it when I purchased a basket case model A . It has a single venturi in it now. Do I need a double venturi in it before it will work?
02-15-2018, 07:10 AM | #8 |
Re: zenith carb
yur carb wil wrk juz fine with no secondary well and a single venturi . I have one running on my early ccpu engine.
02-15-2018, 08:18 AM | #9 |
Re: zenith carb
Look in the intake end of the carb,with the choke open.Are the two jets inline,or offset from one another?If they are inline it is a true double venturi,and if they are offset then it is a single venturi.
02-15-2018, 10:35 AM | #10 |
Re: zenith carb
Bill C. is correct, early '28 carb, single venturi. Mine is the same and it's the original.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
