10-06-2019, 04:20 PM | #21 |
Re: 272 oiling issues
F10 - F-100 CONVENTIONAL V - 239CI 5 - 1955 R - RICHMOND (ASM PLANT) We can try to ID the engine if you want.
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
10-06-2019, 09:17 PM | #22 |
10-07-2019, 07:48 PM | #23 |
While I agree that the 55's came with a 239, who knows what might have been changed over the years. Not unusual to find a later engine in the car or truck.
10-11-2019, 02:44 PM | #24 |
Thanks to all for the excellent help and advice. I rotated the engine 90 degrees, and I have oil everywhere. I was astonished. Thanks again.
10-13-2019, 02:56 PM | #25 |
Pull the rosker shaft and tap the oil passage for 1/8 npt (pipe thread) insert a zerk fitting using a high pressure grease gun pump in the lightest grease you can. You may be able to push the blockage back down and get clean oil moving again. Other wise its pull the head or use an external oil line.
