Old 09-02-2019, 09:57 PM   #1
vern hodgson
Default Door hardware
Looking at this photo it seems as though I need to dig out two pieces of rubber insert new ones then install the brass clips??!
File Type: jpg C988E44D-CD33-4F3C-8FFE-6C8DD48B0F19.jpg (45.6 KB, 79 views)
vern hodgson is offline   Reply With Quote
Old 09-03-2019, 10:36 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Door hardware
yes
www.whidbeymodelaclub.com
Old 09-03-2019, 10:58 AM   #3
Gary Karr
Gary Karr's Avatar
You will also need to reshape and work your new rubber pieces to fit into the door as new ones are not made correctly.
Gary Karr is offline   Reply With Quote
Old 09-03-2019, 02:11 PM   #4
dmaxweb
dmaxweb's Avatar
Snyders has door bumper kits specific to model and year. You may still need to slightly trim them but they are not one size fits all rubber pieces that are out there. There are also different shaped female metal dovetail clips that you may need to order separately. They're cheap and I'd order a couple extra clips. They can be a PITA to get in and if you're like me, you may destroy one figuring out how to install them.
dmaxweb is offline   Reply With Quote
