Old 07-17-2018, 12:35 PM   #1
fcompoccio
Default 40 convertible
Building a 40 convertible Cant identify this brace please help with any info.
See attached photo.
fcompoccio is offline   Reply With Quote
Old 07-17-2018, 02:29 PM   #2
FHFD
FHFD's Avatar
Default Re: 40 convertible
See attached photo.
It's the rear seat rizer..although it isn't an original one.
The original one is cut out in the center for the hump, and has two metal knobs sticking out that accept the seat cushion.
"Get your facts first..then you can distort them as you please"
FHFD is offline   Reply With Quote
Old 07-17-2018, 02:32 PM   #3
19Fordy
19Fordy's Avatar
Could it be the seat riser for the front bottom of the back seat?
The seat bottom rests on this somehow?
Looks homemade as the one's I've seen fit snugly against the tunnel and floor.
Old 07-17-2018, 03:29 PM   #4
Kube
Kube's Avatar
Here's a photo from the trunk vantage point.
Old 07-18-2018, 07:31 AM   #5
fcompoccio
Thanks for the info guys. Guess I can make one from a piece of pine.
Old 07-18-2018, 07:52 AM   #6
Kube
Kube's Avatar
I'd suggest a hard wood. These cross pieces were structural.
Old 07-18-2018, 09:32 AM   #7
rotorwrench
rotorwrench's Avatar
Convertible cars needed the extra cross bracing to help secure the B-pillars. They can get shaky with poor bracing. I'd use ash or white oak if it was me. It looks like the car has had some metal work done in that area. Most converts like to rust in there if not stored well so that isn't unusual.
Old 07-19-2018, 04:30 AM   #8
fortyonerag
fortyonerag's Avatar
Good to know. I assume the same goes for the 41.
fortyonerag is offline   Reply With Quote
Old 07-20-2018, 02:50 PM   #9
fcompoccio
What are the dimensions of the board 2 X?
Old 07-20-2018, 07:51 PM   #10
Kube
Kube's Avatar
If you'd like to make your life real easy, call Roy Nacewicz. he has all the wood pieces available for the '40 convertible. They are BEAUTIFUL reproductions. He had used a great set of authentic boards I'd sent him for patterns. His price for the entire set is not much more than you'd pay for quality lumber.
Old 07-21-2018, 01:46 PM   #11
fcompoccio
Thanks for the info.
How do I contact Roy Nacewicz?
Old 07-21-2018, 05:26 PM   #12
Kube
Kube's Avatar
thanks for the info.
How do i contact roy nacewicz?
734-654-9450
Old 07-22-2018, 07:41 AM   #13
fcompoccio
Thank you so much.
Old 07-22-2018, 08:23 PM   #14
CHuDWah
CHuDWah's Avatar
Thank you so much.
Also has a website although wood parts aren't listed on it:
http://fordscript.com/
CHuDWah is offline   Reply With Quote
Old 07-27-2018, 06:19 AM   #15
fcompoccio
Hi guys
Can you please provide the size of the cross board I need? 2x.
Roy Nacewicz does not answer or return phone calls or Faxes.
Please help Thanks.
Old 07-27-2018, 07:21 AM   #16
Kube
Kube's Avatar
Hi guys
Please help Thanks.
I'm very surprised... he's typically very good about responding. I'd suggest you keep trying.
I hope he is okay....
