Old 04-20-2011, 09:39 AM   #1
32Gnu
32Gnu's Avatar
Default Speedo Turtle.
is my "turtle" cover backwards? does it matter? 32 banjo..
Thanks..
32Gnu is offline   Reply With Quote
Old 04-20-2011, 09:42 AM   #2
ken ct
Default Re: Speedo Turtle.
You cant see the turtle how are we supposed to tell if its backwards?? ken ct Bad pic.
ken ct is offline   Reply With Quote
Old 04-20-2011, 09:50 AM   #3
deuce lover
deuce lover's Avatar
You have it wrong.Its supposed to go pointing to the pass side.
Old 04-20-2011, 09:52 AM   #4
32Gnu
32Gnu's Avatar
Can you see the speedo cable? It can only point one way or the other..
I am wondering if its pointed the wrong way.. I saw another early framed car the other day and the cable went towards the passenger side or does it matter?
Old 04-20-2011, 10:01 AM   #5
deuce lover
Arrow Re: Speedo Turtle.
Here is a pic from The 32 Ford Book.Yes I can see your cable.The cable on an orig car does not go up the left side.It goes thru on the pass side,then thru the firewall (right side)to speedo.
Old 04-20-2011, 10:04 AM   #6
32Gnu
32Gnu's Avatar
Do I need to grease anything in there when I switch it?
Old 04-20-2011, 10:26 AM   #7
deuce lover
If you greased it before it should be fine.
Old 04-20-2011, 06:22 PM   #8
35cab
35cab's Avatar
I think odometer will read backwards that way.
35cab is offline   Reply With Quote
Old 04-20-2011, 06:45 PM   #9
32Gnu
32Gnu's Avatar
thanks guys...
Old 04-20-2011, 07:28 PM   #10
Barry WNY
Did you shorten or cut the tube for any reason? There is one hole that drains the gear oil back into the reared. Need to make sure the passage hole in the tube flange is in the bottom to match the passage in the banjo casting. Had pictures once, otherwise clear as mud?
Barry WNY is offline   Reply With Quote
Old 04-20-2011, 08:03 PM   #11
32Gnu
32Gnu's Avatar
I didn't, hard to tell what was done prior... Thanks again fellas
