Old 06-23-2018, 05:57 PM   #1
Steve Plucker
Default Vintique's Fuse Block Assembly
I bought 2 Fuse Block Assemblies...the ones made by Vintique, and I have a problem with both of them.
First of all these are one of the best accessories on the market for what they do HOWEVER ...just try to get the fuse out. I am unable to get either fuse out because they are so tight in the block itself. If at all, they should come out without any problem but when you got it installed on the starter, it is even harder!
I DO NOT want to try to pry them out with a screwdriver or anything else for fear of breaking the fuse.
I bought some a few years back of which I have one on my 1929 Standard Coupe and can remove the fuse with ease with my fingers, which I do when I am not driving it, because there is a good gap between the fuse and the block itself to allow good upward movement and the fuse comes out with ease.
Has anyone else experienced this problem?
Is there a better one on the market?
Thanks.
Pluck
Old 06-23-2018, 06:04 PM   #2
Will Ziegler in LI NY
Will Ziegler in LI NY's Avatar
Default Re: Vintique's Fuse Block Assembly
I have had that problem, but always thought with electrical connections the tighter the better. So I put a tie wrap around the middle of the fuse and left a little tail to grab if I needed to pull the fuse out.
Will Ziegler in LI NY is offline   Reply With Quote
Old 06-24-2018, 12:06 AM   #3
Chris Haynes
Chris Haynes's Avatar
I always put a zip tie around the fuse before installing it. Very east to pull the zip tie and remove the fuse.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 06-24-2018, 01:11 AM   #4
john charlton
john charlton's Avatar
The zip tie is for sure the way to go as the previous posts advise . I have the zip tie on the starter fuse block made by vintique on 6 cars ,some are very tight but I have never broken a fuse (yet !!!)
John in sunny high pressure over UK Suffolk County England .
john charlton is offline   Reply With Quote
Old 06-24-2018, 06:08 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Some wire terminal kits have plastic pullers, for both the round & the bayonet types of fuses!---Put on on your KEY RING!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-24-2018, 07:50 AM   #6
jhowes
Fun projects sells a waterproof , inline fuse that works perfect. You may want to try it as it is safe and does the job nicely. I had the kind that you are referring to and had it melted to the top of the starter taking out the holder in the process.
Jack
jhowes is offline   Reply With Quote
Old 06-24-2018, 11:06 AM   #7
DHZIEMAN
Thanks.
Pluck
Fuses fit tight to assure good electrical contact and heat transfer! There is a fuse removal tool I carry in my drivers side pocket along with spare fuses. Got it after a situation such as you describe. A picture of a similar type tool is attached
DHZIEMAN is offline   Reply With Quote
Old 06-24-2018, 11:11 AM   #8
Steve Plucker
Thanks Guys...Looks like I need to get one of those fuse tools.
Harbor Freight or NAPA should carry them.
Pluck
