Old 08-21-2018, 01:05 PM   #1
Flathead37
Flathead37's Avatar
Default Labaron & Bonney don't know how to install their tops
Looking for help. I'm trying to install the top on a 33 Cabriolet and LB tech support haven't been very helpful. "We make top kits we don't install them" was the answer they gave.
Without instructions on how to put this together, im reaching out to the Barnners for help.
Any pictures of completed 33 Cabriolet tops would help. Inside, outside, header, etc.
In particular the side header assembly.
Thanks
Flathead37 is offline   Reply With Quote
Old 08-21-2018, 01:21 PM   #2
95476
95476's Avatar
Default Re: Labaron & Bonney don't know how to install their tops
They are going through huge changes at L/B.
These photo's are from my '34 cabriolet.
I am not sure if '33 is the same.
95476 is offline   Reply With Quote
Old 08-21-2018, 02:14 PM   #3
englishdavid
englishdavid's Avatar
I found a video online when i did mine last year, used that as a tutorial
englishdavid is offline   Reply With Quote
Old 08-21-2018, 04:24 PM   #4
TJ
TJ's Avatar
They sold you a top kit without instructions? That is very unlike the LeBaron -Bonney of the old days,.
Old 08-21-2018, 04:34 PM   #5
24ruxstel1339
24ruxstel1339's Avatar
My father installed a few LB tops on Ta and As, this was 30 years ago.
I don't recall instructions and do recall him cutting, sewing, stretching and cursing !!
But he also made a couple from scratch...he was good at it.
Taught himself by hanging around an upholstery shop after work.
24ruxstel1339 is offline   Reply With Quote
Old 08-21-2018, 04:37 PM   #6
Kerk
The founder would be VERY UPSET ar all that is going on or NOT GOING ON! He was a friend who I knew pretty well. Prided his upholstery kits and there quality & fit. JMOP kerk
Kerk is offline   Reply With Quote
Old 08-21-2018, 04:39 PM   #7
Flathead37
Flathead37's Avatar
Thank you 95476 for the pics. Very helpful.
The instructions they sent are poor and incomplete.
The kit included lift the dot fasteners but no mention of where they go.
I got no instructions for rear window placement or top boot installation.
Not sure where to put the snaps.
I'm hoping to get more pictures. Every car I've seen and have pictures of seem to have a different top than the one they sent me.
Old 08-21-2018, 07:07 PM   #8
russcc
Someone on the barn here may have the original instructions that came with LB tops, and may be able to post them. One of the members posted a complete set of LB instructions with illustrations for installing a headliner in '40 coupe.
Old 08-22-2018, 07:20 AM   #9
stangblue
stangblue's Avatar
John I will text them to you. The ones I have are for a 34 roadster.
Assumption is the mother of all foul-ups.
stangblue is offline   Reply With Quote
Old 08-22-2018, 11:30 AM   #10
32phil
I have installed several L B interior kits for both closed and open cars. In addition I have done 3 convertible tops. 2 were L B tops and 1 was for a 56 T bird. I bought some specialty tools and a good electric stapler.
I would say you have to have some innate ability to start with before you tackle a job as complex as an interior/top. I would imagine that any local shop should be able to handle your top installation. Show them the pictures of a finished top in terms of the little details, snaps etc.
If a person doesn't feel comfortable L B has a list of certified shops that will install your kit. I just had a local guy do the seats for a 32 deluxe 2 door I'm working on. He charged me $400 to install the L B kit on the 2 front seats and the rear seat cushions. We used the original seat frames/springs etc. I will install the panel set and headliner etc. myself.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 08-22-2018, 03:13 PM   #11
95476
95476's Avatar
I had a local guy charge me 750.00 to put on L/B covers on a few years ago.
I watched him do much of the work. Never again.
The last 2 I did myself including the headliners with encouragement from TJ.
They came out fine.
I should have been suspicious when I asked how much the job would be and he said he didn't know.
Lucky for him I guess, he needed $750.00 to pay his rent that month.
Old 08-22-2018, 03:39 PM   #12
supereal
supereal's Avatar
I have used L/B successfully for years. Their kits always contained full instructions. If, for some reason, this has changed, it will likely spell the end of the firm. For years they also installed tops, so I am quite surprised they said they no longer install. As for folding tops, I use a very good local auto trim place. Getting it right takes years of experience, and one wrong cut can turn a top into junk. Other interior trim should be easy.
supereal is offline   Reply With Quote
Old 08-22-2018, 04:24 PM   #13
Tony, NY
This video is for a Model A, but should be helpful.
https://www.youtube.com/watch?v=JMqd8SoAAMQ
Tony, NY is offline   Reply With Quote
Old 08-25-2018, 07:53 AM   #14
Zimmco
Zimmco's Avatar
I have the original 33-34 instructions (8 pages) and can send a copy. Send me a pm with your address and give me a few days to get the copies made. I can also send photos as you need them.
Al
Zimmco is offline   Reply With Quote
