03-08-2015, 11:18 AM | #1 |
1940 Ford Rear Light question
I have a "original" 1940 Ford 2dr. Sedan, Standard model with a single tail light. My question is what was the this light originally?? was it just a tail light or was it a brake/tail. The reason I ask is it has been futzed with and has a dual element socket in there now, but I'm suspect as to the originality of it. I'm also installing an aux. brake light and the location of said light will depend on the ability to use the stock lamp as a tail/brake, or strictly a tail.
Thank you in advance |
03-08-2015, 11:27 AM | #2 |
Re: 1940 Ford Rear Light question
it was a running light/brake light combination--required a dual element light bulb. some state required two tailights back-so not uncommon to have had a second light installed in the right rear fender
03-08-2015, 11:45 AM | #3 | |
03-08-2015, 03:54 PM | #4 | |
03-08-2015, 04:04 PM | #5 |
Wiring diagrams are always helpful! The diagram shows the two wires to the taillight, they both go to a dual filament bulb.
03-08-2015, 04:11 PM | #6 |
03-09-2015, 07:12 AM | #7 |
If you are using the original or New replacements and running at night, the lights don't show up very well. To keep people from running into my rear, I took a reflector tape that is used on semi and regular trailers; I installed the reflector tape on a piece of thin flexible metal and formed the metal to go over the bottom lip of the trunk opening and into the tool compartments. Shutting the trunk lid, kept the metal in place and the reflector tape glowed like a light when other peoples headlights shined on the tape. People saw me real good, where before people would tell me that they saw my car before the tail lights.
03-09-2015, 09:32 AM | #8 |
I have a little battery-powered LED unit made for bicycles that I attach to the license plate at night for extra visibility.
03-09-2015, 10:34 AM | #9 |
A third tail light in the rear window is a good idea.
03-09-2015, 11:00 AM | #10 |
As always, thank you for the replies.
I am grateful for your time and consideration. Last edited by buelligan; 03-09-2015 at 01:03 PM. |
03-09-2015, 12:32 PM | #11 |
The original tail lamps were painted black inside, so what little light was produced by the tail lamp bulb was absorbed instead of reflected. Although it would not be "original", you can make your stock tail lamp appear much brighter by simply painting the inside of the tail lamp bright white (remove or mask off the bulb socket before painting.). My family's '40 Fords are both "modified", and run 12 volt electrical systems. I painted the inside of our tail lamps bright white, and installed a 12 volt halogen brake light kit into them. I also added a custom license plate frame that includes a third brake light.
See the attached photo of the rear of dad's '40 Tudor. He simply has his headlights on, but you can see how lit up the tail lamps are (It is too bad dad was not stepping on the brake, but you can see the unlit third brake light over the top of the license plate.). Best regards, |
03-09-2015, 01:21 PM | #12 |
Now look at the truck tail light in front of the 40! LOL The license thing is kinda cool.
