08-30-2016, 01:36 PM | #1 |
One more step.
The cowl section of my 29 tudor is in epoxy primer. Primer surfacer tomorrow. Block sanding comes next. Then comes the color coat. Then finally I get to color sand and buff. I must be nuts! But at least being on the "barn", I know I am not alone.
08-30-2016, 02:51 PM | #2 |
Re: One more step.
Agreement with every statement! Wayne
08-30-2016, 03:10 PM | #3 |
Re: One more step.
You surely are not alone. I'm doing some color sanding and buffing as well. Let me know if this link works.
https://flickr.com/photos/[email protected] Congrats on getting closer to being done. |
08-30-2016, 03:22 PM | #4 |
Re: One more step.
The link works. That is a beautiful reflection. Is that base coat/clear coat?
08-30-2016, 05:19 PM | #5 |
Re: One more step.
[QUOTE=pgerhardt;1346690]The link works. That is a beautiful reflection. Is that base coat/clear coat?[/QUOTE
It is a single stage. This was my second time doing a cut and buff. I'm always scared to ruin the paint but I just kept getting a little more aggressive till I started seeing results. |
08-31-2016, 09:51 PM | #6 | |
Re: One more step.
08-30-2016, 04:03 PM | #7 |
Re: One more step.
to me the '29s, with the coupe pillar, the small hood, the front fender design, bumper design, etc. create a cute "antique" appearance to them. I know there are negative aspects to the 1929 models but I'm speaking merely of aesthetics.
anyway thanks for the pics. |
08-31-2016, 09:48 PM | #8 |
Re: One more step.
One of them is the 29 steering column. I solved that problem by having Randy Gross convert mine to the F-100 steering box!
08-31-2016, 10:01 PM | #9 |
Re: One more step.
If you lay on 3 decent coats of SS or clear you should have enough to work with....when dry each coat is 1 mil, and you will color sand off 1 mil.
Too many newbies try to skimp on the paint....ya gotta have paint on there to work with....and passes should overlap 50%
'31 180A |
