Old 06-21-2019, 01:52 PM   #1
HalcyonDays
HalcyonDays's Avatar
Default Fuel Gauge
Are there any tricks to removing a stuck on fuel gauge?
HalcyonDays is offline   Reply With Quote
Old 06-21-2019, 02:10 PM   #2
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
Default Re: Fuel Gauge
Are you using the correct tools? I'm ask because after the outside and inside nuts are removed there's really nothing much to hold it on. The old cork seal should come off pretty easy.
MickeyT is offline   Reply With Quote
Old 06-21-2019, 02:40 PM   #3
HalcyonDays
I do have the correct tools and have taken a few off. This one is really stuck and looks like it has been on for a long time. The tools I have are made out of aluminum and are slipping off, but they work fine on another car I have. I am thinking the gas may have turned to shellac, hoping for some solvent tha would help loosen it up.
Old 06-21-2019, 08:42 PM   #4
Rich in Tucson
Rich in Tucson's Avatar
Sounds like you need the steel tools, I was involved in removing one by which we had to use a cheater pipe out the passenger window; I put my weight on the pipe while the owner put his weight on pressing the tool inward so it would not slip. I feared we needed his wife on the driver's running board to counter the torque effect before it finally broke free!
Rich in Tucson is offline   Reply With Quote
Old 06-23-2019, 02:03 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I had one and had to do the same as Rich.
I agree that the steel tools probably will be less likely to slip off.
Old 06-23-2019, 02:21 AM   #6
Synchro909
Synchro909's Avatar
[QUOTE=Tom Wesenberg;
I agree that the steel tools probably will be less likely to slip off.[/QUOTE]
Agreed here too. Those aluminium ones sold by the vendors are of poor quality.
Old 06-23-2019, 10:04 AM   #7
larrys40
I would try a heat gun to see if you can soften the old gas varnish that is probably still king the outer nut. At the point you don’t care about the inner. Just the outer. I use an original 5z gas gauge wrench and it fits perfectly and makes the job easier. The steel repro units probably do fit better in lieu of the 5z tool.
You can try a little penetrant around the nut but I still think a heat gun with a little light heat will help.
Larry shepard
larrys40 is offline   Reply With Quote
Old 06-23-2019, 07:32 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I had 2 repop guages with plastic lens. They turned brown & stuck the guages. Bought 2 kits with glass lens & problem solved!
Bill Tricky
"THE ASSISTANT GURU OF STUFF"
Old 06-23-2019, 09:38 PM   #9
updraught
updraught's Avatar
The new aluminium ones are useless. Too big.
http://jmodela.coffeecup.com/fixgasgauge.html
updraught is offline   Reply With Quote
Old 06-24-2019, 08:34 AM   #10
MickeyT
No one mentions why the new tools are made of aluminum. Fire safety. I've used them to repair the gauges on both my As and they worked fine,
Old 06-24-2019, 12:19 PM   #11
burner31
burner31's Avatar
Have you tried.....
Keith
Shawnee OK
'31 SW 160-B
Old 06-24-2019, 12:33 PM   #12
Don Turley
Don Turley's Avatar
I have the aluminum tools. The problem with them is that they are cast aluminum and the corners are too rounded. I had modify mine by using a Dremel Tool to make the corners a bit sharper and deeper to make sure that it seated properly on the outer nut. After I did that, it works fine, every time.
Don Turley is offline   Reply With Quote
Old 06-24-2019, 01:00 PM   #13
F.M.
The Originals from Ford were Steel.. Steel on Brass..
F.M. is offline   Reply With Quote
Old 06-24-2019, 06:41 PM   #14
MickeyT
Which do you think cost more in Ford's day. Would explain his choice.
Old 06-25-2019, 03:17 AM   #15
updraught
updraught's Avatar
See how the aluminium one slopes outwards:
https://www.snydersantiqueauto.com/i...ize/A_9300.jpg
"A well made cast aluminum heat treated tool set for the Model A gas gauge. Will not damage the chrome nuts."
Supposedly. After the corners were rounded off the nut, the petrol tank cleanout man used one of these, it altered the Art Deco look somewhat.
Old 06-25-2019, 12:09 PM   #16
Don Turley
Don Turley's Avatar
It is much less expensive to cast them in aluminum than to machine them from steel. Because they are cast, the inside corners of the tool for the outer nut are rounded causing the tool to not fully seat around the nut. I used a Dremel Tool to make the corners sharper so that the tool will seat better onto the nut, therefore giving a better grip for turning. After doing this, I've never had a problem with the tool.
Old 06-25-2019, 08:32 PM   #17
HalcyonDays
Thank you all for the suggestions. I did end up ordering a steel tool which arrived today. I had sprayed some penatrating oil on the gauge and let it sit over the weekend. Today when the steel tool arrived the nut turned without the wrench slipping off. On to the next project.
