Old 02-25-2019, 01:43 PM   #1
GranTrevino
Default Need help identifying Mallory distributor model.
I need some help identifing a Mallory distributor. The plate on the side has the model number as 2301105. The problem is, I am needing to find an advance spring kit for this distributor, but all documents that I can find for that model have a different weight set and advance plate then what I have. Any help is appreciated. I.e. a part number for a spring kit, model number of distributor.
I have purchased a spring/advanced curve kit from summit racing. It was not correct. I believe that the springs are to short and the max advance gauges are not correct for the advance that I have(they do not fit).
https://photos.app.goo.gl/u7mPXFPnEE8s7Bv46
https://photos.app.goo.gl/XjRQhHQ7fdhrxeiV8
https://photos.app.goo.gl/VRX2ErUedKqCBcD58
GranTrevino is offline   Reply With Quote
Old 02-25-2019, 02:26 PM   #2
CarlG
CarlG's Avatar
Default Re: Need help identifying Mallory distributor model.
Try Bubba's Ignition in Indianapolis
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-25-2019, 02:44 PM   #3
GranTrevino
I currently have a PM to Bubba's ignition. Awaiting reply.
Old 02-25-2019, 11:55 PM   #4
jetmek
I think Mr Gasket owns Mallory now. I haven't had any luck obtaining parts from them
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 02-26-2019, 12:25 AM   #5
updraught
updraught's Avatar
Looks like you are gunning for
"2301105 18 degrees @ 2000 RPM"
https://static.speedwaymotors.com/pdf/500-2318001.pdf
Should be fairly soft springs to advance quickly, I'd think, but might depend on head.
updraught is offline   Reply With Quote
Old 02-26-2019, 06:29 PM   #6
d.j. moordigian
d.j. moordigian's Avatar
You DON'T NEED SPRINGS OR WEIGHTS..
The 2 round holes are for moving the arms that hold the springs,..changing the speed
of the advance.
You also need the "key" too set the amount of advance,..the 2 arms with a screw in each,..the arm end fits in the slot. There 2 styles of slots for the key,..you need the
round style..
Dudley
d.j. moordigian is offline   Reply With Quote
