Old 03-03-2024, 12:03 PM   #1
Jarhead354
Default Reverse light switch location
Restoring a 53 Victoria. Long story short, can someone tell me where the reverse light activation swatch is mounted? Additionally, a picture would be great. Thanks in advance.
Jarhead354 is offline   Reply With Quote
Old 03-03-2024, 12:06 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Reverse light switch location
Probably on the transmission or linkage is my guess. I don't own a 53.
Old 03-03-2024, 12:37 PM   #3
Jarhead354
Thanks for the reply ��. We had the transmission rebuilt over a year ago but we failed to document the removal of this switch. Hoping someone has knowledge of where it’s mounted.
Old 03-03-2024, 01:17 PM   #4
tubman
tubman's Avatar
On my '51, it is on the linkage midway down the steering column in the engine compartment. I was able to buy a reproduction switch and bracket a couple of years ago, I believe it was from "Shoebox Central". My car doesn't have backup lights, and I don't expect to add them because they are obvious and kinda ugly. I added it to activate a backup camera, which I find much more useful than backup lights. Given the mechanical similarities, I'll bet the same setup will work on a '53.
EDIT : I just checked and they list the bracket for '49-'51, but not '52-'53. I'll bet you could make one work though.
Old 03-03-2024, 01:37 PM   #5
Jarhead354
Awesome! Thanks for the info. I’ll take a look at the location you mentioned. The car is at a warehouse and not here at my home so I can’t look at it now.
Old 03-03-2024, 02:18 PM   #6
Old Magnet
Same bracket for 49-53, part number 51A-15517. Works of the shift lever/arms at base of steering column.
Old Magnet is offline   Reply With Quote
Old 03-03-2024, 02:26 PM   #7
Jarhead354
Thanks!
Old 03-04-2024, 08:58 AM   #8
Merc Cruzer
Merc Cruzer's Avatar
This might help. It is on a 53' Mercury, but should be the same for Ford.
Merc Cruzer is offline   Reply With Quote
Old 03-04-2024, 11:45 AM   #9
petehoovie
petehoovie's Avatar
Old 03-04-2024, 03:00 PM   #10
pistonbroke
It depends on what transmission you have. It goes on the column and is actuated by the first/revers arm on the standard or it will be the neutral safety switch as shown above for the fordomatic.Tim
Old 03-13-2024, 10:47 AM   #11
Jarhead354
Thanks for the images. These really help!
