Old 01-08-2012, 02:44 AM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Model T manifold with Model A carb
Have any of you seen this type of set up.
Not a professional job, but I wonder how good it might run.
Regards, Neil
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 01-08-2012, 08:50 AM   #2
tmodelman
tmodelman's Avatar
Default Re: Model T manifold with Model A carb
With that long drop leg on the intake, so the big Model A carb clears the frame rail, at least the gas flow to the bowl would be good
tmodelman is offline   Reply With Quote
Old 01-08-2012, 11:46 AM   #3
Jalopy Tin
I use a 26-27 vaporizer intake upside down with a home made connection to the Tillotson X carb. Runs perfect!
Jalopy Tin is offline   Reply With Quote
Old 01-08-2012, 06:12 PM   #4
John Otis
John Otis's Avatar
Send a message via AIM to John Otis Send a message via Yahoo to John Otis
I saw a similar A carb setup once but it was made from plumbing fittings. One of the best running T's I ever saw had a homemade intake and a big old carb that had come off a big 2 cylinder combine engine. Wisconsin I think.
John Otis is offline   Reply With Quote
