Old 02-15-2018, 02:00 PM   #1
Dave Castle
Dave Castle's Avatar
Default Aluminum radiator ?
Any thoughts, pro or con, on using a aluminum radiator ? Running a 59A with the new style Speedway water pumps, engine is stock.
Dave Castle is offline   Reply With Quote
Old 02-15-2018, 02:37 PM   #2
drolston
drolston's Avatar
Default Re: Aluminum radiator ?
My '41 came with a truck radiator wedged into place. It was just a matter of time for it to wear through where the top tank was wedged between the top of the fenders. But it never overheated.
Replaced it with a Champion aluminum radiator rated at 500 hp and it will overheat at idle, even after putting on a (partial) shroud and a spacer to move the fan closer to the radiator. I can not bring myself to put an electric fan on it, but that is what is required to move enough air through that radiator at idle.
If you can restore the stock radiator, I think you will be better off.
Old 02-15-2018, 03:24 PM   #3
35ragtop
35ragtop's Avatar
When I rebuilt my 38 pickup, I installed an 3 core aluminium radiator designed for the flathead. I have a 59 a engine with all stock running gear. I took care to run earthing wires and use and corrosion inhibitor fluid. In our hot Queensland climate it can run hard at 60 mph on the hot freeway and idle in traffic and never overheat. Make sure your block is clean, absolutely no crud floating around.
It was a lot cheaper option than having the old radiator rebuilt, but if you are building a “points car” then it will not be right.
Dave
35ragtop is offline   Reply With Quote
Old 02-15-2018, 03:56 PM   #4
TJ
TJ's Avatar
If you ever get a hole in the aluminum radiator they are "toast".
Old 02-15-2018, 04:17 PM   #5
Karl Wescott
Karl Wescott's Avatar
The big advantages of aluminum is weight and cost, which are critical for new car makers beancounters and racers. With a well designed and constructed radiator efficiency marginally favors copper/brass. IMHO durability strongly favors copper/brass. Another critical issue is having the correct design side plates where the grille and (sometimes) fenders attach.
An electric fan will generally not move as much air as a well positioned mechanical fan, however the energy usage is less for electric (and electric can easily be turned off when not needed). A good "flex" fan will move the most air. Shrouding the fan and having the fan centered in the radiator are very important.
There is no best answer.
Karl Wescott is offline   Reply With Quote
Old 02-15-2018, 04:28 PM   #6
RalphM
RalphM's Avatar
If you can afford it, go brass/copper. Well worth the extra expense. Although I know people running aluminum, and they do work ok .
RalphM is offline   Reply With Quote
Old 02-15-2018, 05:31 PM   #7
J Witt
J Witt's Avatar
So far I'm pleased with the Brassworks radiator for my '36 phaeton. Not an exact copy, but close in appearance and a good mechanical fit into the cramped space in the nose. I have had cool running, but have not been through a Georgia summer yet.
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 02-15-2018, 05:31 PM   #8
JSeery
JSeery's Avatar
I'm not a fan of aluminum radiators, but as already stated some people are. I run a Brassworks.
Old 02-16-2018, 12:52 AM   #9
1932tub
Wrong. We fix heaps of alloy motocross radiators, straightened, and leaks repaired no problem.
1932tub is offline   Reply With Quote
Old 02-16-2018, 05:53 AM   #10
flatmotor40
flatmotor40's Avatar
I have a Griffin aluminum radiator in my 40 and it cools fine an winter I can't get enough heat to keep inside warm.As I say that it will probably go out next time I drive it
flatmotor40 is offline   Reply With Quote
Old 02-16-2018, 09:56 AM   #11
TJ
TJ's Avatar
How are they repaired?
Old 02-16-2018, 11:09 AM   #12
woodiewagon46
Dave, I both restore and hot rod cars. I subscribe to a few hot rod related magazines and there have been articles about aluminum and copper radiators. The rage at one time was aluminum radiators in hot rods. What the articles report is, that as far as cooling they are just about the same. Repairability can be an issue with aluminum. By asking a question such as yours will only add to your confusion. Aluminum radiator users will say that they are the best and copper users will say they are the better. I use brass-copper, I feel they look more like the stock application, aluminum just "stands out" too much and to me doesn't look right in an early car.
woodiewagon46 is offline   Reply With Quote
Old 02-16-2018, 01:22 PM   #13
D. Jones
D. Jones's Avatar
Cost was the reason I went aluminum and so far I have about 20,000 miles on it and no complaints. If it doesn't give good service I'll consider a brass and copper one.
D. Jones is offline   Reply With Quote
Old 02-16-2018, 05:04 PM   #14
1932tub
We use a material called stickit which is like a pastic welding stick.
It is flowed in using an oxy acetelene torch.
On the odd occasion we use a tig.
