05-27-2011, 07:22 PM | #1 |
Oops! Left the ignition switch on 40 Ford Truck
Hey Fellas, HELP!!! I was pulling up in the driveway and the truck stalled. I was going to push it up in driveway and got sidetracted. Left the ignition switch on, not knowingly. I thought that when i started it up to move it, it cranked a little slow. I put a battery charger on it not knowing that the on/off switch was on all that time. Now nothing!!! Stupid rookie move... What do i look for first, New Optima battery and a new rebuilt Bubbas Diz. Where do i start??? Thanks Ken
05-27-2011, 07:29 PM | #2 |
Re: Oops! Left the ignition switch on 40 Ford Truck
Define "nothing". Crank, no start. Or NO crank, no start?
Building a 29 Sedan on 32 chassis........ very slowly.... |
05-27-2011, 07:43 PM | #3 |
No Crank No Start Ken
05-27-2011, 09:29 PM | #4 |
I think you might have two problems. I would check the switch to make sure power is going though and after you fix the no crank problem you might have a no start problem with the coil or points.
05-27-2011, 09:46 PM | #5 |
i did that once, the switch was left on for a week, the battery was completely dead.
charged it up and everything was ok, actually i think i did it twice !!!
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
05-27-2011, 10:07 PM | #6 |
Go hard, or Go home |
05-27-2011, 10:30 PM | #7 |
I would think that if you were lucky and the points were open when you charged the battery, your coil would be ok. Check all connections from battery to starter.
05-27-2011, 11:14 PM | #8 |
I did that once! before I had my electronic ignition and burned the points.
05-28-2011, 07:48 AM | #9 |
When you hooked up the batt charger was it hook up right like pos. ground ect? Walt
05-28-2011, 08:08 AM | #10 |
I ran an Optima battery back when they first came on the market and when it died, it just died. Don't overlook the obvious. If the battery won't pass a high rate discharge test it's time for a new one. If it charges back up and turns the starter OK, go on to the coil, condenser, & points.
Kerby |
05-29-2011, 01:34 AM | #11 |
Probably fried the coil I have seen this many times
Twice Pipes C.C. |
05-29-2011, 07:19 PM | #12 |
Wow!! I got lucky... Charged the battery and it fired right up. Typical Ford LOL Thanks Guys!! Ken
