Originally Posted by Tom Endy
Photos are of a tool to pull the pinion assembly and drive shaft out of the banjo without disturbing the pre-load setting (if one is actually still there). Comes in very handy when installing an overdrive where all you want to do is pull the drive shaft assembly without disassembling the entire rear axle assembly.
Please feel free to down load and use any of my photos.
Tom Endy
Is this similar to the "Pinion Puller" that Mitchell loans out when installing an overdrive?
