Old 05-21-2020, 11:07 PM   #1
Mike the Grump
Default 28 roadster frame vs 30 coupe frame
From what I've discovered through search and catalogs and what not, it appears they are at least dimensionally the same. Is that correct?
Mike the Grump is offline   Reply With Quote
Old 05-21-2020, 11:09 PM   #2
Charlie Stephens
Default Re: 28 roadster frame vs 30 coupe frame
The height of the pads for the radiator is slightly different.
Charlie Stephens
Old 05-21-2020, 11:20 PM   #3
Mike the Grump
Perfect Thank you
Old 05-21-2020, 11:24 PM   #4
Charlie Stephens
The mechanical brake linkage will be different and the hand brake will be on the left for early '28. If you are doing a restoration the fender braces and running board brackets will be different. What is the whole project?
Charlie Stephens
Old 05-21-2020, 11:47 PM   #5
Dave Mellor NJ
The handbrake is on the right on early right hand drive cars
Dave Mellor NJ is offline   Reply With Quote
Old 05-21-2020, 11:52 PM   #6
Jack Shaft
the front body mount bracket is back 2 1/2 inches on the 30 frame..
Old 05-22-2020, 03:45 PM   #7
rotorwrench
rotorwrench's Avatar
One of our resident model A enthusiasts has very good research data that he put together for all to study. You will need adobe reader for the PDF files.
http://www.plucks329s.org/frame.htm
