Old 08-12-2019, 11:42 AM   #1
artron9
Default hesitation
My 52 v8 was running rich with #51 jets. Dropped two sizes to#49's. I'M getting a slight hesitation when I start to accelerate. I adjusted the fuel mixture with my vac gauge and increased the idle speed to about 600 rpm in Drive. Would the drop in jet size be the cause?
artron9 is offline   Reply With Quote
Old 08-12-2019, 12:14 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: hesitation
Sounds more like the accelerator pump needs attention (longer stroke position).
If it's an automatic, the idle speed in neutral should be closer to 500 RPM or less.
Old 08-12-2019, 01:40 PM   #3
artron9
Hi Merc 51, I thought the hole nearest the throttle shaft was for hot temperature and the far hole was for cold weather? Should I try the far hole(longer stroke)? Thank you!
Old 08-12-2019, 01:49 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Yes, by all means try the longer stroke position. (it is possible that the pump is defective)
Old 08-12-2019, 08:39 PM   #5
artron9
Thanks 51 Merc-ct, I moved the position to the right(cold setting). Noticed some improvement. Will test it again tmrw and let you know! I appreciate our input!
Old 08-13-2019, 07:46 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
If you did notice some improvement then it appears that the accel. pump needs to be corrected as it is not supplying enough fuel shot off idle which can be the cause of hesitation.
Old 08-13-2019, 11:08 AM   #7
artron9
Thanks 51Merc-CT
I rechecked the pump and lubed it. Pump seems ok. Did not check the squirt though? Still have the hesitation. Maybe I should put the #51 jets back?
Old 08-13-2019, 11:50 AM   #8
drolston
drolston's Avatar
Thanks 51Merc-CT
Check the squirt in both barrels before you change jets. Weak stream means accel pump plunger loose fit, or blocked passage.
Old 08-13-2019, 02:00 PM   #9
51 MERC-CT
51 MERC-CT's Avatar
Thanks 51Merc-CT
No amount of lubrication will fix a faulty accel. pump, it needs to be replaced if faulty.
Old 08-13-2019, 03:28 PM   #10
artron9
Thank you both for your suggestions! i have a new plunger coming!
Old 08-14-2019, 05:23 AM   #11
Pete F.
Check the vacuum and than check the power valve setting.
With the fatter jet you didn’t need the extra fuel on acceleration but now since the mixture is leaner you need fuel enrichment till your up to speed. If the power valve is opening to late you will get hesitation.
Sent from my iPad using Tapatalk
Pete F. is offline   Reply With Quote
Old 08-15-2019, 02:26 PM   #12
artron9
Thank you all: I have decided to go back to the #51 jets. Hesitation is gone? again, I appreciate all of your concerns!
