12-31-2018, 10:32 AM | #1 |
1931 headlamp bar
Since I have had this 1931 Model A I have been looking for a better headlamp bar but do not know how to identify an original. Were they a stamped steel tube,fabricated or some sort of a casting? Were there different suppliers to Ford and different ways that they were made or later reproductions I need to stay away from.The very first one I did buy was modified over the years evidently for a different set of headlamps as my originals would not fit or adjust correctly to set level.Many on Ebay but some sellers do not even know what year of the 4.Thank You.
"Never complain,never explain"... Henry Ford II |
12-31-2018, 12:40 PM | #2 |
Re: 1931 headlamp bar
There are 3 basic versions of headlight bars for the Model "A:"
1. The 1928 & 1929 versions have sharp curved ends to fit the front fender curvature of these cars; 2. Early 1930 bars have are stamped steel with a channel cross-section; 3. The balance of 1930 & 1931 bars are a welded assembly of tubes. The bar you seek is in the picture.
Bob Bidonde |
12-31-2018, 01:16 PM | #3 |
I don't think I've ever seen a reproduction bar.
Bob |
12-31-2018, 01:26 PM | #4 |
You probably have. Most of the chrome plated dropped ones are repro. From my experience, the stamped steel ones are mid-1930 |
12-31-2018, 01:43 PM | #5 | |
You are correct again Brent, I was thinking of stock shape but if they reproduce the dropped I assume it would be easy to reproduce a stock type. |
12-31-2018, 02:04 PM | #6 | |
12-31-2018, 03:15 PM | #7 |
on the 30-31 watch out for the angle where the head light mounts. they should be at a downward angle. they did make some early reproductions the are flat. like for mounting different head lights on. I have two of them, and one is painted.
12-31-2018, 03:35 PM | #8 |
I one saw one where the owner had the bar on backwards and the headlights could no be adjusted. The owner was thinking it had been modified and was going to heat it and try bending it. After changing it end for end all was well.
12-31-2018, 03:46 PM | #9 |
Contact Bert's in Denver for a correct one.
Happy New Year ! ! ! Paul in CT |
12-31-2018, 04:21 PM | #10 |
12-31-2018, 06:30 PM | #11 | |
01-01-2019, 04:14 PM | #12 | |
https://www.fordbarn.com/forum/searc...11591899&pp=25 https://www.fordbarn.com/forum/showt...=headlight+bar https://www.fordbarn.com/forum/showt...=headlight+bar https://www.fordbarn.com/forum/showt...=headlight+bar
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
