02-11-2021, 09:08 AM | #1 |
Distributor and cam issue
I recently bought 3 distributor rotors from 3 different suppliers - all 3 rotors appear identical, except for the small numbers on the inner surface of the rotor...which I believe are injection molding machine numbers.
All of the rotors are a loose fit on two different distributor cams I have; the tab on the rotor that fits into the cam notch is too small, resulting in some fairy significant play between the cam and rotor. I have one much older rotor which is a very snug fit on the cam. Has anyone else encountered this, and, if so, do you have a simple solution to remove the play between the two parts ? Thanks - Jim |
