10-04-2019, 05:08 PM | #21 |
Re: T5 Shift Problems
10-04-2019, 08:29 PM | #22 |
Something not mentioned but I have experienced. Damaged snout cracked or broken the throw out bearing hub rides on can cause damage to the pilot bearing.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
10-05-2019, 04:53 AM | #23 |
10-07-2019, 03:11 AM | #24 |
Well for now I adjusted the clutch pedal and so far, so good. I didn't get a lot of driving time, but it definitely shifted better Thanks to all
10-12-2019, 04:07 PM | #25 |
Are the clutch and pressure plate in good shape and the right ones?
If they are worn enought they may not allow the gearbox to shift smoothly. |
10-12-2019, 05:36 PM | #26 |
