Old 04-01-2020, 09:37 PM   #1
Mongo
Default One inch wide insert bearings
Pulled and engine apart. Two observations.
1) It has insert bearing on the rods. The inserts were centered in the rod journal but were only one inch wide, not the usual width of the rod.
2) There is machined welds on each side of the rods and rod caps to replace the babitted side thrust portion of the babitted bearing.
Has any one seen this before?
Mongo is offline   Reply With Quote
Old 04-01-2020, 10:35 PM   #2
MikeK
MikeK's Avatar
Default Re: One inch wide insert bearings
Yes, common before the AER and other replacement insert rods were made.
MikeK is offline   Reply With Quote
Old 04-02-2020, 09:59 AM   #3
Mongo
Thx Mike ---and no kidding
Old 04-02-2020, 12:02 PM   #4
Jim Brierley
Yep, commonly done. The bearings could be Volvo?
Old 04-02-2020, 05:13 PM   #5
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Originally Posted by mongo View Post
pulled and engine apart. Two observations.
1) it has insert bearing on the rods. The inserts were centered in the rod journal but were only one inch wide, not the usual width of the rod.
2) there is machined welds on each side of the rods and rod caps to replace the babitted side thrust portion of the babitted bearing.
These were from an H&H engine
J and M Machine is offline   Reply With Quote
Old 04-03-2020, 08:58 AM   #6
MrBruce
MrBruce's Avatar
Yes, there were a number of different bearings during my years with Clevite Engine Bearings I sent hundreds of bearings out to independent guys who were inserting Model A and B blocks. I remember REM was a big one. Now Rich had bearings manufactured that fit and will bring the Model A engine into the 21st century. Any machine shop will be able to install the inserts which are available from most of our Model A supply houses. They also come with new rods made for the inserts. I can't wait to send Rich my engine with over 30 years on it for inserts.
MrBruce is offline   Reply With Quote
Old 04-03-2020, 10:17 AM   #7
Benson
Benson's Avatar
Old 04-03-2020, 12:11 PM   #8
Jim Brierley
I chose Volvo because they are thinner than most bearings so less material was removed from the B rods. They have held up well, 167 mph on the salt, bearings still look good.
