Old 01-14-2020, 09:14 PM   #1
hotrodA
hotrodA's Avatar
Default 40 Heater recore??
I had my 40 heater headed toward a resurrection until I found a miniscule leak in the center of the core.
Radiator guys x2 says it can't be fixed, but he can have a core custom made for only $250 or so. YIKES
So, can anyone (a) recommend a DIY fixit solution (b) a replacement modern core or (c) have a good used 40 core?
Or, do I find a heater core catalog and hopefully find one with same dimensions and change the tubes out?
Thanks!
hotrodA is offline   Reply With Quote
Old 01-14-2020, 09:17 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 40 Heater recore??
Contact these folks: http://ucvintagerad.com
Old 01-14-2020, 09:24 PM   #3
drolston
drolston's Avatar
Faced with an $800 re-core, I painted a thick coat of liquid FlexSeal on some miniscule leaks (more like weeping) on my radiator. It has held up for about 1000 miles on some hot days and with a 7 lb radiator cap. I bronze brushed the adjacent surface nice and clean.
So, if you can get to the leak with a little brush, it might be worth a try.
Or, Barr's StopLeak is pretty good on pinhole leaks.
Old 01-14-2020, 09:25 PM   #4
Kube
Kube's Avatar
Radiator guy x2 says it can't be fixed, but he can have a core custom made for only $250 or so. YIKES
Thanks!
Solder works wonders...
Old 01-14-2020, 10:21 PM   #5
hotrodA
hotrodA's Avatar
Kube,
Radiator guy says that he can't repair that type of core construction, if that's what you're referring to.
Maybe I need to find another guy? I drove 75 miles to Knoxville to this guy. They're all going out business. He bought the equipment from the best guy who had been in business since 1923.
Fortyniner,
Good tip, thanks!
Old 01-15-2020, 04:55 AM   #6
oldskool
oldskool's Avatar
I just had my 40 recored for $200 by cap-a-radiator a real rad shop not too many left who work on vintage cars,i wish drake or somebody would repro old ford heater cores,im sure they would be swamped with orders
oldskool is offline   Reply With Quote
Old 01-15-2020, 09:05 AM   #7
JSeery
JSeery's Avatar
Just a thought. Had a friend with a 65 Comet that developed a major leak while he was driving it. It was blowing very hot radiator fluid on him and he wrecked the car. Now, this was a later pressurized system, but something to keep in mind. A major heat core leak while driving is not a good thing, so might want to be sure the core is in good shape. Any repair should be of good quality. Lability might be a shops concern for a repair of this type inside the car.
Old 01-15-2020, 02:58 PM   #8
oldford2
oldford2's Avatar
Try YouTube "radiator leak repair" dozens of do it your self videos for repairs from solder. JB weld, epoxy, etc
John
oldford2 is offline   Reply With Quote
Old 01-15-2020, 03:52 PM   #9
derek costello
Princessauto has heater cores (non descriptive) that they sell new for 5bucks.
Two of these put together would fit in your heater box and give far more heat than the original! Just connect the two together with a short hose and the two remaining connections will go to the water feed..............
derek costello is offline   Reply With Quote
Old 01-15-2020, 04:00 PM   #10
philipswanson
[QUOTE=,i wish drake or somebody would repro old ford heater cores,im sure they would be swamped with orders[/QUOTE]
You don't want to get one from backorder Bob. It would end up being Chinese. Better to get original re-cored.
philipswanson is offline   Reply With Quote
Old 01-15-2020, 09:32 PM   #11
richard crow
take a pair of needle nose plyers go about an inch bellow the leak & pinch the tube several times toward the leak. do the same above the leak.that,s what we did years ago when you could get a new core for 8 dollars
richard crow is offline   Reply With Quote
Old 01-15-2020, 09:48 PM   #12
tubman
tubman's Avatar
Generally, I have found that repairing leaks in heater cores is a loosing proposition. They deteriorate over time, and once they develop a leak, another can soon follow. While changing heater cores on per-war Fords is pretty easy, it can be a real challenge on later model cars. I prefer to do it once and be done with it.
Old 01-15-2020, 09:58 PM   #13
deuce_roadster
deuce_roadster's Avatar
A core the same thickness that is larger can be cut down (both for width and length) and the stock tanks with supply tubes can be soldered on. A friend who used to work in a radiator shop told me they used to take new cores and cut them down with a hand saw, then solder the old tanks on.
Old 01-15-2020, 10:01 PM   #14
Branded
Branded's Avatar
I also have had a local radiator shop cut a core down to size and use the tanks from my provided core. This was on my 54 F100.
Branded is offline   Reply With Quote
Old 01-16-2020, 09:28 AM   #15
corvette8n
corvette8n's Avatar
Found this, I never shopped with this vender, but I will see if I can fit one of these in my '41
https://www.universalpartsinc.com/shopping/?ic=10552
Advance Auto also lists a car quest one.
Old 01-16-2020, 04:36 PM   #16
hotrodA
hotrodA's Avatar
After the great tip from FortyNiner, I emailed http://ucvintagerad.com
They called me back today with a quote of $89 for a bare core.
8"x8"x2-1/4". You use your old tanks and tubes.
I also found a Chrysler heater core at my parts store that would work. $41 !!!.
7.5"x7.75""x2". Tubes are 5/8", but are short and straight, unlike stock.
Easy to adapt if you're not restoring exactly.
Thanks for all of your suggestions.
