Old 10-26-2019, 10:06 PM   #1
tommyleea
Default 55 F100 Master Cylinder
So, my next project is brakes. Master cylinder is missing. Just stock brakes, and the master cylinder mounts on the frame. I know there should be a distribution block somewhere to direct the fluid to front and rear brakes. I don't see any on the frame. Would it be mounted on the master cylinder? Shop manual is unclear. Thanks
tommyleea is offline   Reply With Quote
Old 10-27-2019, 06:17 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: 55 F100 Master Cylinder
Below are ILL's of the 55 FI00 System -
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-27-2019, 07:07 AM   #3
tommyleea
Default Re: 55 F100 Master Cylinder
Thanks..Don't know how I missed that. It appears all the lines go into a fitting on the master cylinder itself.
Old 10-27-2019, 07:35 AM   #4
KULTULZ
KULTULZ's Avatar
The Ill is from a FORD PARTS BOOK.
- WHY IS IT ... -
Old 10-27-2019, 07:28 PM   #5
paul2748
paul2748's Avatar
Looks like part # 2076 is the block.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-28-2019, 11:08 PM   #6
mobileparts
If you would like a U.S.A. manufactured NEW Master Cylinder ( and Wheel Cylinders, Brake Shoes, Brake Hoses, etc., etc.),
Call me -- Craig -- 516 - 485 - 1935.... West Hempstead, Long Island, New York....
mobileparts is offline   Reply With Quote
Old 11-07-2019, 02:35 AM   #7
mobileparts
You aren't going to fix it, after all??????
Old 11-07-2019, 11:22 AM   #8
tommyleea
Fighting kingpins right now. Thanks for the info...
Old 11-08-2019, 12:21 AM   #9
mobileparts
I have U.S.A. made King Pins and Pin Kits also.....
You have the phone number -- no fighting required.....
Old 11-23-2019, 12:35 PM   #10
tommyleea
That is the part I need. Distribution block that bolts to the master cylinder. Would anyone have one laying around? Maybe converted their brakes from the single master cylinder, and still has this part? I have one on order, but it is backordered, and it doesn't look promising at this point. Any help would be appreciated.
Old 11-23-2019, 03:34 PM   #11
KULTULZ
KULTULZ's Avatar
8C 2076 - GOOGLE that PN and you will find it.
File Type: jpg Brake System - 1955 F100 _3 - MC Fittings.jpg (15.1 KB, 2 views)
- WHY IS IT ... -
Old 11-23-2019, 10:54 PM   #12
tommyleea
Thanks...I did find it, and it is on order, but it is backordered.
Old 11-24-2019, 01:46 AM   #13
KULTULZ
KULTULZ's Avatar
Question Re: 55 F100 Master Cylinder
Try EvilBay?
https://www.ebay.com/itm/1948-56-For...-/352485779573
- WHY IS IT ... -
Old 11-24-2019, 12:31 PM   #14
poolplayer1
Sorry to get into this matter but I have a question for Kultulz. Do you by any chance have a parts breakdown and maybe part #'s of the emergency brake ? I am missing some parts so would like to identify them so i can order and install in my 55.
It is a 1955 ford Ranch Wagon. I saw the diagram above but my car has a different design that this one. Thank you kindly.
poolplayer1 is offline   Reply With Quote
Old 11-24-2019, 03:17 PM   #15
tommyleea
Thanks KULTULZ..I did look on Ebay, but the one I looked at was out of stock. Your number worked, and it is on order. Cheers!
Old 11-24-2019, 04:23 PM   #16
KULTULZ
KULTULZ's Avatar
Here you go. The ILL is broken into two parts as my scanner is on the fritz.
Give me the PN's you need from the Ill and I will post the complete PN.
- WHY IS IT ... -
