Old 07-26-2020, 03:39 PM   #1
bluardun
bluardun's Avatar
Default Model T rear axle nut
What is the torque spec for the rear axel/hub nut? thanks
bluardun is offline   Reply With Quote
Old 07-26-2020, 07:15 PM   #2
39portlander
39portlander's Avatar
Default Re: Model T rear axle nut
Using the guidance from Milt Webb aka. "Dr T" on page 47 of his "restoring a ruckstell for a model T" it say's...
"withboth rear wheels on the floor torque the axle nuts to 80 ft.lb. Then, torque the axle nut more to line up the castellation slot for cotter pin installation." That spec is good even if you do not have a Ruckstell axle.
Remember to check drum rotation and brake lining drag before and after. Good luck and let us know how you make out.
39portlander is offline   Reply With Quote
Old 07-26-2020, 08:32 PM   #3
redmodelt
redmodelt's Avatar
I take mine to 90 then to next slot. If at 90 the next slot is quite a ways from lining up, I file a little off the nut or swap them around. Be sure to recheck a couple of times after that. I yet to find a car that does not need to retorqued a couple of times. Have had a number of cars come in the shop that was done once and never again!
Old 07-26-2020, 08:37 PM   #4
Royce P
Royce P's Avatar
There is no torque spec for anything on a Model T Ford. No torque wrenches existed at the time. You tighten the nut as tight as you dare and then install a cotter pin.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 07-26-2020, 09:04 PM   #5
redmodelt
redmodelt's Avatar
That is not completely true. Torque was set by the length of the wrench used and where the average person could turn it till it stopped. That is why wrenches come in different lengths. The spark plug wrench when used properly yields about 45-50FPs of torque to the head bolts. Just because there may not have been torque wrenches presay, does not mean engineers did not understand torque values when making tools.
Last edited by redmodelt; 07-27-2020 at 05:24 PM. Reason: added "to the head bolts", spark plugs do not need to be that tight.
Old 07-27-2020, 03:41 PM   #6
bluardun
bluardun's Avatar
Thanks. Great help.
Old 08-30-2020, 02:29 PM   #7
A bones
A bones's Avatar
In the words of Ted Aschman author of "Tinkerin' Tips" it needs to "gut bustin' tight".
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 08-30-2020, 06:12 PM   #8
Aarongriffey
Actually the correct torque is: stop just before something breaks or strips.
I have found model T, and later car owners, who insisted that you just tighten the nut until there is no play between the drum hub and the axle.
They obviously don’t understand the setup. You are not adjusting play on a bearing.
Aarongriffey is offline   Reply With Quote
Old 05-29-2023, 04:58 PM   #9
Crandalj
I replaced bearings, brakes, bearing springs, seals and axle keys. When I reinstalled hubs and tried tightening the nuts, wheels locked up and wouldn’t turn. Had to back off the nuts enough so wheels would turn. What may I be doing wrong?
Crandalj is offline   Reply With Quote
Old 05-29-2023, 07:20 PM   #10
redmodelt
redmodelt's Avatar
First you really need to start your own post. Could be hubs are worn, the outer housing seal cap is not on far enough, brake shoes are getting crushed between the backing plate and drum, etc. The list could go on. We would need more information to make any kind of guesses.
Old 05-30-2023, 12:05 PM   #11
CatMan1
I've noticed this one mine, too. Is it possible then that the axle shaft is worn and I need to add shims?
CatMan1 is offline   Reply With Quote
