02-12-2024, 05:58 PM | #1 |
34 pickup floor board/toe board/trans cover fasteners?
So mocked up my wooden floor board, metal toe or foot board and transmission cover to see how they fit together. I have no fasteners for any of these. The floor board has no holes in it so it must be a new old remake of the original or could be original.
It looks like I need to drill holes in floor board that line up with welded nuts on the cab floor and bottom edge of metal foot board. What size/length bolts? What size/length bolts are used to fasten metal foot board to firewall? Looks like wood screws would needed to fasten transmission cover to floor board? What size/length fasteners? I see online there is a pedal/column rubber seal. I assume it goes on top off foot board but how is it held into place? And this rubber seal is almost $40! Wow. Lastly, what covers the floor/foot board? Sound deadening mat/carpet/rubber mat ? I’d appreciate some pictures for reference. Thanks. |
02-12-2024, 06:54 PM | #2 |
Re: 34 pickup floor board/toe board/trans cover fasteners?
The #2 floorboard (made of plywood) is attached to the fore and after and cross sills will 1/4 - 20 flat head countersunk machine screws with 1/4" countersunk washers, both with an S-2 (black oxide) finish as was the #1 floorboard.
The transmission cover was attached to the #2 floorboard with short #14 countersunk wood screws and 1/4' countersunk washers. The pedal/column seal fits between the #1 steel floorboard and the stamped steel separate cover. A taupe rubber mat covered the #1 and #2 floorboards. |
02-12-2024, 07:55 PM | #3 | |
02-12-2024, 10:08 PM | #4 |
Yes. I'll see if I can find a photo of it for you.
02-12-2024, 10:22 PM | #5 | |
02-13-2024, 04:36 AM | #6 |
02-13-2024, 07:10 AM | #7 |
#12-24 for '32s, 1/4-20 starting with the '33s.
02-13-2024, 07:10 AM | #8 |
This the piece? Of course original would not be chrome. This one on eBay for $75.
02-13-2024, 10:09 AM | #9 |
That's it.
02-13-2024, 12:06 PM | #10 |
